Crackling radio (1 Viewer)
johnp10
7,774
15,181
North Lincolnshire
8 years ish
The cab radio in my van works well with the engine off.
Good, clean sound across all wave bands and stations.
With the engine running there is a lot of static like crackling.
Not what I would have expected from a diesel engine.
Any ideas?
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Usually a bad earth on the aerial input or the aerial mount. You can unplug at the back of the receiver and short out the aerial then if you still get crackle it's not the aerial.
johnp10
johnp10
7,774
15,181
North Lincolnshire
8 years ish
Thanks, Brian.
Would you expect that crackling to be present with the engine running only, or in any event if it's an earth problem?
I'll try to figure out how the radio comes out.:whatthe:
SuperMike
2,477
7,593
St Albans
Winnebago Sightseer
Have you got anything running on usb, like an adapter plugged into the gig. socket. They can throw out loads of mush. :Smile:
WynandJean
6,670
3,303
West Midlands
Bailey Autograph 682
Since 2010
Yes, sounds typical of aerial problem.
Wyn
Daifuse
183
310
Milford Haven
c class
Since 2011
Possibly an alternator problem - how old is it? Intermittent sparking on the slip rings on the rotor can be to blame.
johnp10
johnp10
7,774
15,181
North Lincolnshire
8 years ish
2000.
It has been suggested that the suppressor in the alternator may be suspect.
Hope it's an aerial problem.
Cheapest fix.
sean n maggie
672
327
leeds
autotrail
usualy a suppressor,,,you used to be able to get a in-line suppressor dont know if you still can, sorry,,,:Sad:
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Thanks, Brian.
Well you are saying it's only with the engine running.
To slide it out you need a tool, two U shaped pieces of wire that you insert into four small ( 3mm ) holes in the facia. Ebay or Halfrauds.
johnp10
johnp10
7,774
15,181
North Lincolnshire
8 years ish
Thanks, Brian.
I'll have a go at that.
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
John, drop off at any car shop and buy an in-line power filter. You just fit in into the radio main power supply line. It sounds that you may have a diode going down in your alternator, which can cause an interference crackle, that goes faster as you rev up. I have even heard of this problem setting up a radio (5th) harmonic, whereby the set itself transmits the crackle for short distances around the alternator, and then receives it's own signal back, putting it over the speakers. :thumb:
Wyaye wires
3,333
9,263
Berwickshire
A class Neisman Bischoff
since July 2009
Just change the bloody radios name..... :Doh:
to... :whatthe:
Rose... ::bigsmile: and sing along... :thumb:
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
Since 2012
It is also worth rewiring it to your leisure battery. As well as isolating it somewhat from your noisy alternator, this means you can use it for hours with the engine off and still be able to start.
Oct 28, 2013
490
443
Lincoln
Van Conversion
Have you fitted any LED Vehicle Running Lights?
Some of the LED Units will affect the radio reception causing a loud, distinct hissing noise which will go away when the lights are switched off.
Chris
21,053
278,733
None
10 years
I had a problem with crackling in the cab.
My solution was to ban roast pork sandwiches from the cab area.
Immediate solution.
Hope that helps:thumb:
johnp10
johnp10
7,774
15,181
North Lincolnshire
8 years ish
No, none fitted, but useful info.
Thanks.
Immediate solution.
THAT'S IT!!! :thumb:
The benefit of a University education, eh? :notworthy:
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
As my old grandad used to say....."University of hard knocks" ::bigsmile:
