Corner steadies (2 Viewers)
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
I took a gamble with these off ebay £145 delivered (removed from a 5 ton Frankia lowline) and at first I thought I'd cocked up but it turned out well in the end.
The grey waste was the stumbling block but with a modification to the mounting bracket it just fits. If you see any for sale grab them!
2x8mm holes to drill for each side but these are right at the end of the chassis and won't cause any weakness.
GJH
29,450
38,827
None, now sold
2006 to 2022
Nice job.
There were steadies already fitted to our Burstner when we bought it. There were also blocks of wood (as you have) in the locker for putting underneath but I found that they got a bit wet in use and were a bit of a pain to retrieve when we left site.
As luck would have it we had an old plastic chopping board which we no longer used so I cut it in half (making two pieces about A5 size) drilled a couple of holes in each and used some old electrical flex to make a loop handle. They work well to stop the steadies sinking in the ground, are easy to retrieve and wipe clean.
peter marshall
2,466
1,704
Cleveleys,Lancashire
Low Line
9 Years
I Bought two last night from O'Leary £55 inc Postage , hope they fit when I get them. :Doh::Doh:pete
Oct 29, 2012
887
1,045
essex
Rapido 9090df
20 years (unless you count my dads VW which makes it 52 years with a few gaps!!)
stops all that rocking about dont they:Blush:
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Ahh Atwoods they're like the ones I've not removed yet but they're well in front of my axle and as much use as an ashtray on a motorbike to my van :roflmto:
Make sure you don't forget to put them up before driving off!
My new ones will fold up if I forget :Cool:
GJH
29,450
38,827
None, now sold
2006 to 2022
[HI]Make sure you don't forget to put them up before driving off![/HI]
I place the winder over the pedals when I've put the steadies down so that it's there as a reminder.
mick noe
Apr 14, 2009
638
539
near Boston Lincolnshire
low line
never tried mine on the rapido seems steady enough without, obviously not as energetic as you lot:winky: Do you need a special tool to lower them as I do not appear to have one...................just re-read that not sure that reads right:Eeek:
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
The standard legs require a round bar that you insert and lever the legs taught
Mine uses a 17mm socket on a hex shaft driven by 18 volt LXT Makita ::bigsmile:
Chris
21,056
278,967
10 years
I wouldn't bother with them.
Part of the fun is waking the family when I go out for an early morning smoke::bigsmile:
mikebeaches
5,395
8,603
Bristol
Rapido V68 Van Conversion
We never used the steadies when we had a Rapido.
Mike
MHVirgins
3,889
3,158
South of Scotland
March 2011
We have steadies on our van, I believe they come as standard on the Dakota, but haven't tried them down yet. Had a look for the tool which should've been left with the van when we bought it last year........but can't see it.
Does anybody know where I could get a spare "winder"?
Thanks in advance.
Bill
GJH
29,450
38,827
None, now sold
2006 to 2022
[HI]Does anybody know where I could get a spare "winder"?[/HI]
Thanks in advance.
Bill
You can probably source one from a caravan supplies company but if you have the correct size socket and an extension bar that will probably work just as well.
Sep 25, 2009
794
1,386
south yorkshire
since 2004. Tugger 10 years on and off
PUT SOME MUD FLAPS ON.MINE ON RAPIDO GET COVERED IN MUCK & ARE A PAIN TO USE.:Smile:
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
These are for sale. Will be removed this week. First £50 secures no offers! Not Shiny anymore but perfectly serviceable
11,843
14,074
Never used my steadies. I have thought of removing them to save weight, but never got around to it.
JockandRita
11,464
150,225
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
We've used ours once in eleven years of ownership Andy, as when tried, didn't make a blind bit of difference with out tandem axled MH. :(
The only time they get wound down and up again, is for servicing. ;)
Cheers,
Jock. :)
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
No worries Jock, anyone who wants them will have made their own mind up (y) just like I did and I found they help.
