Angus dog
Just back from first trip with Cheyenne 696.Fabulous weather.However I noticed a fair bit of condensation in one headlamp.Should I be concerned ?what are the likely causes ?Thanks in anticipation
As already stated, it will be the rubber seal on the back of the headlight often people change a bulb and find it difficult to put back on - so they do their best or leave it off. Other cause my be the seal between the lense and glass. Rarer, but possible.
[HI]To 'Cure' it,[/HI] check the rear sealing cover, if unattached - that would be the cause. Remove cover/bulb and pop a hair dryer in the lense to dry it out. Allow to cool, and then refit the bulb/sealing grommet and that will be done.
[HI]Modern headlight units are not sealed, as such, they should have ventilation holes to allow any water to evaporate. [/HI]
One reason for water ingress is a blocked scuttle drain causing water to cascade over the back of the light unit. Also, if you regularly park on uneven ground, with the scuttle outlet pipe at the high side water will flood the drain without the outlet being blocked.
First make sure the unit vent is not blocked then find the water source.
