Coke? (2 Viewers)
Aug 19, 2015
639
11,770
West Sussex
Hello all. I'm sure I read here some time ago that pouring a bottle of coke down the kitchen sink helps get rid of any gunge. Is this correct?
If so do I just pour it down and leave it? How long for? The sink takes ages to drain away- if not coke , what else?
Thanks.
Louis
1,204
982
Anglesey
Fiat Ducato Auotrail
6 Months with motorhome(35 years tugging)
sorry error
Hellski
989
2,972
Cheltenham
N+B Arto 76 LE
Coke is used but I'm not sure of quantities or how long. Personally I prefer to use specific products, Fenwick's gets good reviews and similar products are available from other manufacturers. Link
I've not used the above product in anger so can't personally advise on its effectiveness for your issue but it does state that used at a higher concentrate, it will unblock and as a plus smells nicer than coke!
Cal54
3,806
62,054
Southport, UK
Leisuredrive Renoir
Since 1996
A couple of litres of cheap cola added to your waste tank via any of your outlets(kitchen sink, shower tray, wash basin) and then drive a bit to agitate leave a short while and then drain. This has worked for me.
icantremember
8,333
17,545
Near to Watton in Norfolk
Hymer T-SL668
since 2005
I gave up using coke 'cos it never tastes the same afterwards and ruins the Bacardi!:eek:
We now use washing soda .... a good dose down each plughole followed by a kettle full of hot water. Best to do it before travelling so it stays in the tank and gets swilled around, then empty and flush before it gets a chance to settle.(y)
mike mcglynn
Jan 6, 2008
2,700
32,552
St. Helens MERSEYSIDE
Autosleeper Warwick XL
A long time now
We use a product called tank cleaner, from memory I think its made by Elsan works very well and one bottle lasts us all year(y)
Armytwowheels
6,475
14,881
Market Harborough
Carthago S Plus - Iveco
Since 2011
I had recent success with the oxyclean stuff that is meant for stain removal for laundry. I used Lidl's own brand and put a half measure down each plughole followed by a bit of hot water. Don't use to much hot water as you don't want to flush it straight through. It will fizz and foam for a while and then settle down.
When I did this on the shower tray plughole it actually bought up grains of sand in the foam.
appydaze
728
1,848
southend on sea essex
Merc high top
20 years
How does the Bacardi taste with the wqshing soda?....... not tried that cocktail yet......:Eeek:
23,836
72,511
We use a litre of pure orange juice after a tip from Richard ( @Scotties )
About once every couple of months seems to work for us
Nov 18, 2011
11,862
43,046
Planet Earth
A van
Over 25 year's
Baking coda and citric azide put sum citric. down the plug hole then pore sum diluted baking coda it will come up and carry the crap out the pipes and in to the tank
Then level till next time you empty works for me
Calgone dose a good job to
Bill
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
My new van only drains slowly from the sink, unless it is full and it goes fast until empty, I think there might be a non return,anti smell ,valve that needs a bit of weight to open fully. Check your it might be the same.
43,332
49,505
And the washing soda IS ok with Bacardi then ? :LOL:
Bart
3,188
1,398
Northern Ireland
Boxer L4H2 van build
Since 2016
don't know if coke etc will fix a slow emptying sink, but it will help clean out your tank and make it smell better , also make sure the filter it clear , mine is below the MH , right below the sink
Mar 21, 2010
2,486
2,993
Tesco "cola" 17p bottle works well. Put 10 bottles in the tank via kitchen, bathroom and shower plug holes. Drove about fifty miles to churn it up a lot of gung came out.
colyboy
Mr Milliemobile
Sep 9, 2016
81
388
North Yorkshire
Since 2014
Would diet version of cola be better than full fat version? Thinking that all that sugar could feed the bugs, bacteria and mould in pipes and waste tank...
icantremember
8,333
17,545
Hymer T-SL668
since 2005
colyboy
At 17p each the gunge probably was in the bottle when purchased! ;)
Bart
3,188
1,398
Northern Ireland
Since 2016
colyboy
What size of bottles were they at 17p each. surely not 1ltr ?
To right , my thoughts exactly :D :D
