Coke?
Discussion in 'Motorhome Chat' started by The Cruisers, Sep 17, 2016.
  1. The Cruisers
    The Cruisers Funster
    Aug 19, 2015
    1,199
    3,727
    West Sussex
    Hello all. I'm sure I read here some time ago that pouring a bottle of coke down the kitchen sink helps get rid of any gunge. Is this correct?
    If so do I just pour it down and leave it? How long for? The sink takes ages to drain away- if not coke , what else?
    Thanks.
  2. Louis
    Louis Funster
    Mar 29, 2016
    244
    117
    Anglesey
    sorry error
  3. Hellski
    Hellski Funster
    Mar 28, 2016
    170
    117
    Cheltenham
    Coke is used but I'm not sure of quantities or how long. Personally I prefer to use specific products, Fenwick's gets good reviews and similar products are available from other manufacturers. Link
    I've not used the above product in anger so can't personally advise on its effectiveness for your issue but it does state that used at a higher concentrate, it will unblock and as a plus smells nicer than coke!
  4. Cal54
    Cal54 Funster Life Member
    Apr 25, 2014
    1,400
    8,477
    Lancaster
    A couple of litres of cheap cola added to your waste tank via any of your outlets(kitchen sink, shower tray, wash basin) and then drive a bit to agitate leave a short while and then drain. This has worked for me.
    • Like Like x 1
    • Thanks Thanks x 1
  5. icantremember
    icantremember Funster
    Sep 2, 2010
    5,344
    7,467
    Nr Watton in Norfolk
    I gave up using coke 'cos it never tastes the same afterwards and ruins the Bacardi!:eek:
    We now use washing soda .... a good dose down each plughole followed by a kettle full of hot water. Best to do it before travelling so it stays in the tank and gets swilled around, then empty and flush before it gets a chance to settle.(y)
    • Like Like x 2
    • Funny Funny x 2
  6. mike mcglynn
    mike mcglynn Funster Life Member
    Jan 6, 2008
    1,414
    5,720
    St. Helens MERSEYSIDE
    We use a product called tank cleaner, from memory I think its made by Elsan works very well and one bottle lasts us all year(y)
  7. StitchesnFluff
    StitchesnFluff Funster
    Oct 18, 2014
    1,230
    520
    Salisbury
    Once cleaned maintain with elsan grey waste fluid
  8. Armytwowheels
    Armytwowheels Funster Life Member
    Aug 10, 2012
    4,107
    6,699
    Spain for the winter
    I had recent success with the oxyclean stuff that is meant for stain removal for laundry. I used Lidl's own brand and put a half measure down each plughole followed by a bit of hot water. Don't use to much hot water as you don't want to flush it straight through. It will fizz and foam for a while and then settle down.
    When I did this on the shower tray plughole it actually bought up grains of sand in the foam.
  9. solo 1
    solo 1 Funster Life Member
    Oct 12, 2009
    361
    898
    southend on sea essex
    How does the Bacardi taste with the wqshing soda?....... not tried that cocktail yet......:Eeek:
    • Like Like x 1
    • Funny Funny x 1
  10. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,615
    22,772
    Narrfoook
    We use a litre of pure orange juice after a tip from Richard ( @Scotties )
    About once every couple of months seems to work for us
  11. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,244
    12,915
    somewhere
    Baking coda and citric azide put sum citric. down the plug hole then pore sum diluted baking coda it will come up and carry the crap out the pipes and in to the tank
    Then level till next time you empty works for me
    Calgone dose a good job to
    Bill
  12. GWAYGWAY
    GWAYGWAY Funster
    Sep 6, 2014
    2,077
    1,468
    Dover
    My new van only drains slowly from the sink, unless it is full and it goes fast until empty, I think there might be a non return,anti smell ,valve that needs a bit of weight to open fully. Check your it might be the same.
  13. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,952
    17,628
    YO11 2BD
    And the washing soda IS ok with Bacardi then ? :LOL:
  14. icantremember
    Sep 2, 2010
    5,344
    7,467
    Absolutely ... just have to increase the percentage of Bacardi in the mix!:beerchug:
  15. Bart
    Bart Funster
    Jun 4, 2016
    1,721
    501
    N.Ireland
    don't know if coke etc will fix a slow emptying sink, but it will help clean out your tank and make it smell better , also make sure the filter it clear , mine is below the MH , right below the sink
  16. colyboy
    colyboy Funster
    Mar 21, 2010
    744
    633
    Tesco "cola" 17p bottle works well. Put 10 bottles in the tank via kitchen, bathroom and shower plug holes. Drove about fifty miles to churn it up a lot of gung came out.
    colyboy
  17. Mr Milliemobile
    Mr Milliemobile Funster
    Sep 9, 2016
    44
    327
    North Yorkshire
    Would diet version of cola be better than full fat version? Thinking that all that sugar could feed the bugs, bacteria and mould in pipes and waste tank...
  18. icantremember
    Sep 2, 2010
    5,344
    7,467
    At 17p each the gunge probably was in the bottle when purchased! ;)
    • Funny Funny x 2
    • Like Like x 1
  19. Bart
    Bart Funster
    Jun 4, 2016
    1,721
    501
    N.Ireland
    What size of bottles were they at 17p each. surely not 1ltr ?
    To right , my thoughts exactly :D :D
    • Like Like x 1
