Coachmen Mirada, Liberty edition, slide out
Discussion in 'Coachmen' started by Colin and Jaen Andrews, Nov 25, 2009.
  1. Colin and Jaen Andrews
    Colin and Jaen Andrews Read Only Funster
    Aug 18, 2008
    200
    34
    Gloucestershire
    Hi everyone
    Back in RV world again :BigGrin::BigGrin::BigGrin:
    Libby not up for sale anymore decided we loved her too much so as personal life nearly back to normal back in the real world full timing. Yippee :thumb::thumb: So happy.
    Do have question re slide out. While off site (no hook up) we had probs getting slide out back in. Started stopped started stopped. Only way was with generator running. Not having technical brains we thought doh.:Rofl1::Rofl1::Rofl1:
    Back on site and she struggled a bit but went out.
    Just been for mot (passed - brill) and slide out struggled to come in before we went while still on hook up. Came back and went out ok. doh.
    Anyone give us a clue????
    Is it motor?
    leisure batteries
    Not sure how it is powered.
    Yep dumbo when it comes to technical.
    Thanks in advance
    Cheers Jaen and Colin
  2. peaps
    peaps Funster
    Feb 3, 2008
    159
    25
    SWINDON
    Don't know if this will help but when the same happened to me it was the house battery was nearly flat when the genny was started it gave the batteries the lift neccessary,whatit meant was I needed new batteries.
    Hope this helps
    Pete:thumb:
  3. zaskar
    zaskar Funster
    Sep 25, 2007
    984
    96
    UK
    A likely culprit is corrosion/bad connections/damp caused by lack of use.
    The motors themselves are usually pretty reliable.
    Check
    1 battery condition
    2. battery connections
    3. motor connections
    ........and a real good one (which nobody ever does:Blush:) is get underneath with a tub of grease and throughly grease all the mechanism and gear wheels. It'll reduce friction and thus wear on the motor and it'll run and sound a hell of a lot smoother.
    edit = ps, I forgot. Another good thing to do is spray the slideout seals with a propper silicon spray. When I did mine, it made a heck of a difference. You can get it from any RV spares supplier such as Linda or Duncan on here.
  4. dazzer
    dazzer Read Only Funster
    Jul 30, 2007
    1,698
    99
    In my house
    Silicone spray is also available from any plumbers merchants. Plumbers use it on push fit connections on waste pipes......a bit of lube goes a long way!!!:thumb::Wink:
  5. Colin and Jaen Andrews
    Aug 18, 2008
    200
    34
    Gloucestershire
    many thanks
    thanks for info - when it stops raining!!!! will grease and spray and see how that goes and will get batteries checked.
    What a fantastic site for help - always an answer
    Cheers:thumb::thumb::thumb:
  6. madbluemad
    madbluemad
    Jan 26, 2008
    3,341
    243
    spain
    Thats what happened to me. All it needed was greasing. It now gets a regular lube as do the slide seals.
    Jim
    :Smile:
  7. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,687
    5,844
    Mansfield,Notts
    I'm 99% certain that grease on the cogs is a definitive No No check with Duncan at Star Spangled Spanner before doing any thing:Eeek:
    Geo
  8. zaskar
    zaskar Funster
    Sep 25, 2007
    984
    96
    UK
    So we're gonna run intermeshing gears with no lube?:Eeek:
    Not gonna happen, not on my truck:Cool:
    The only argument I can think of is the possiblity of the gears slipping........and the only way that can happen is if the mechanism has excess play in it allowing the gears to move apart........and thats another problem all together.......(IMHO:Smile:)
  9. matamoros
    matamoros Funster
    May 15, 2008
    2,352
    3,572
    Rochdale, Tavira, S. Brittany & Europe
    When I got 5er last year lubrication of slide out was something that concerned me as everything, slides gears etc, were dry.I did a little research on the internet but I cannot recall exact details, possibly manufacturer or US owners web site, the advice was not to grease because of contamination from road spray, dirt etc.Consequently I have not greased mine but I am not totally happy with this, coincidentally I was underneath today and noticed a fair amount of surface rust on the slides.
    If nobody comes up with anything definitive I may try and do a little more research.
  10. moandick
    moandick Read Only Funster
    Jul 28, 2007
    1,318
    112
    Landrake, Cornwall
    I use an aerosol can of motor cycle chain grease. It sticks to the rails and gears but does not form lumps large enough to attract contaminants. I simply cannot accept that contaminated grease can cause any more damage than a NO grease situation and I promise you, my slides are in and out like yo-yo's. (Cornish winds!).
  11. matamoros
    matamoros Funster
    May 15, 2008
    2,352
    3,572
    That sounds like a good idea, don't get much more exposed to road spray etc than a motor cycle chain.
  12. brianju
    brianju Funster
    Sep 18, 2007
    171
    35
    Hampshire Hogs now in Mid Wales
    No slides on our trek, but in one of my lockers is a can of PROTECT ALL slide-out dry lube protectant - resists dirt,salt etc - I used this on the slide-out of the 5th wheel I used to have, I also used the rubber seal conditioner.
    Both these products I ordered from my bible the RV accessories catalog (through Duncan) but if you get one of these catalogues beware! there are loads of goodies to drool over and you will spend a fortune :Eeek: including a great range of party lights :BigGrin:
    Brian
  13. damondunc
    damondunc Funster
    Aug 2, 2007
    101
    15
    near Lincoln
    slide out gears
    by all means grease the rollers and sliders, according to manufacturer of most rv slideouts with rack and pinion gears, these gears should NOT be greased. They have a tendancy to jump teeth, the worst case is on a four motor four rack system on a certain make of rv that went out of skew due to this, the electronics gizmo to reset this lot cost a fortune.
    Dunc.
  14. Colin and Jaen Andrews
    Aug 18, 2008
    200
    34
    Gloucestershire
    Libby
    Hi everyone many thanks for info have done the biz on the slide out :thumb::thumb:- see what happens when we use again - not brave enough now as its soooo cold and do not want to be out faffing around.:Rofl1::Rofl1:
    Not sure how to take Libby off the for sale on system - prob blonde moment but hey ho.:Eeek:
    Any help would be appreciated
    Many thanks.
    Cheers Jaen
  15. Colin and Jaen Andrews
    Aug 18, 2008
    200
    34
    Gloucestershire
    Libby slide out - yeh yeh
    Thank you so much for help - we used chain oil and the biz on the rubbers and yeh yeh slide out came in. Magic. :thumb::thumb::thumb: Fingers crossed after xmas when we move again.:BigGrin:
    Just for a laugh for some we have since had 'me' blonde moment. :Rofl1::Doh:
    Oh no - no hot water. usual checks and boiler fireing and stopping etc etc. OK yes did not take on board that water pump kept kicking in. :Doh:Senior moment ' didnt it always do that!!!!' NO NO NO. :Rofl1::Rofl1:- ok so got help - Can wash up with kettle but shower !!!.
    Called local motorhome medics - brilliant guys :thumb::thumb:- yeh if we were in the know we should have known - but hey ho - leaking and spraying water on the system which said I can fire up but now I am wet!!.. All now sorted and brilliant. :thumb:
    Oh to be understanding all the technical bits would be amazing but we love the people that can help - yeh cost us but not stupid money. Just little bit more overtime being jolly green giant at local supermarket!
    Cheers Jaen and Col:thumb::thumb:
  16. pkurzok
    pkurzok Read Only Funster
    Jun 22, 2010
    60
    australia
    greasing gears
    hi guys
    grease is ok as long as you clean it off and regrease every 12 months as the grease attract the dirt and water and this can blind things as well.
