Clutch problems (1 Viewer)
lou020
489
360
huddersfield
autotrail chieftain
since 2010
why did you remove the engine ?, managed to do mine with it in, as long as you get the front end high enough to drag the gear box and bell housing away.
Oh,, and you don't mind being layed on your back for ages.
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
since 2007, 25 years tuggin before that.
With an X250 Ducato with a 3.0 engine?
You must show me how!
ShiftZZ
21,383
84,579
Dark Side of the Moon
I nearly boo booed. I misread the heading. I was going to suggest some antibiotics.
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
Good good, probably saved a fortune doing it your self, its always great to hear of better ways, than just replacing like for like. Some of the big converters could probably fit these before they leave the factory to save later breakdowns.
After all £400 is a very little in comparison to some of these big vans over 4 to 5 tons that usually have the bigger engine.
Keep up the good work and thanks for the info.
lou020
489
360
huddersfield
autotrail chieftain
since 2010
did it with the one in the picture on the left, i too had read reports that the engine had to be removed on the 3.0.
But it's rubbish.
The hardest part was getting it jacked high enough so the bell housing cleared the bumper.
we removed the n/s engine mount and let the engine drop sideways. could probably even do it with the exhaust still connected.
also, took us ages to find the little 10 mm bolt holding the conversion plate to the engine, and it wouldn't let the bell housing come away.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
The fleet of Mercedes ambulances that the Scottish Ambulance Service had with automated clutches didn't give a blink of trouble. I personally had a 2.7 wagon with this type of clutch which was eventually retired with over 400K on the clock & never had a clutch replaced! This was an "on-call' wagon which would sit outside with coating of ice & snow, started & then driven flat out within seconds. The Peugeot ambulance that they have now cannot go for a full week without a breakdown, the brakes catch fire, the clutches go & various suspension faults. The service are looking at scrapping them early due to poor reliability.
My paramedic daughter has strong views on ambulance base vehicles too :D.
I did say 'potential' and I wasn't referring to any particular make. The manufacturer must take a view on smoothed changes vs clutch life for any robotised manual because as I said the only mechanism available to the ECU is the clutch.
TheBig1
17,630
43,280
my 3.0 ltr clutch was changed with the engine in place in about 7 hours. as said remove nearside engine mount and lower, plus some of it was done via the nearside wheel arch with suspension dropped and plastic liner removed. but it was on a lift, not sat on the ground on a driveway
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
Well, all finished by lunchtime, including a couple of other little jobs.
What a difference! well worth the effort & if Borg & Beck's claims are true, it should last about 450,000 miles.(y)
Would definately recomend this clutch kit to replace the Iveco (Yes they were Iveco, not Fiat Parts) Clutch & Dual Mass Rubbish.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Is it suitable with comfortmatics? I think most likely not
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
As far as I know it is the same clutch & flywheel set up, it's just a robotised clutch operating system.
Ring Borg & Beck & ask them, I found them very helpful, They wouldn't supply me direct but gave me a couple of local motor factors to choose from.
KUSKUS
Apr 12, 2013
1,069
2,171
Shrewsbury
Carthago 144
just a update on our clutch problems on our five comfortmatic buses, NOW SIX yes six out of the twenty two out of service, costing a fortune on hire buses.
syldale
12
United Kingdom
model
years
hi i was just wondering if you had any reverse judder & if so did it cure the judder its good to know there is an aftermarket job ( borg&beck ) which is better than the factory fitted crap but also that's the drawbacks of a remap you do get clutch slip pulling 6ton & that's being light footed no boy racer here wrong side of 66
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
No, no reverse judder before or after. My 3 litre has also been remapped ( in persuit of economy, but the power is tremendous). Only drawback is a slight vibration between 1500 & 1800 rpm , but I,m more than happy to live with that for the overall benefits.
syldale
12
United Kingdom
model
years
hi thanks for your reply i will have fitted the Borg&beck when the time comes off in January for a few months (Portugal ) she slips ( for about 2 seconds ) at about 2000rpm when changing gears picking up speed like you said the power is tremendous especially up hill but i drop down to 5th & back in cruise never had any slip so i will just see how she goes my self i think its the pressure plate going weak & not the clutch plate just like yours because it doesn't slip when cold
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
Sounds like the symptoms I had. When you strip it out you will almost certainly find it's the DMF that's failing, as mine was.
syldale
12
United Kingdom
model
years
thanks again i think the dmf is the thing that makes the judder looking at the makeup of springs etc but the dmf was developed to stop the vibration so that why fitting a borg is a the down side
