Cleaning out fresh water tank (1 Viewer)
May 10, 2012
407
22,220
Portugal
Don’t own one.
Since 2006(1986 VW T25)
Question is how often do you clean your tank if ever. I have some stuff called Puriclean but it says pump out the tank after use and do not swallow, so not sure with this stuff. Any thoughts or ideas would be useful.
Feb 16, 2013
19,734
52,021
uttoxeter
ambulance conversion
50 years
I think you would be better leaving that stuff in its carton;):)
PP Bear
7,806
28,776
Kent, UK
Auto Trail Dakota SE
Use these, they do a perfect job :)
Jun 30, 2010
7,924
27,229
Cornwall
1992 VW Auto sleeper Mono
Since 2005 this time
Purisol to clean and sterilize the tank and pipes, Aquasol to keep the water in the tank fresh after
About £8 ea, One word of advice however;
Read the bloody instructions on the bottles before you start!!!
I've been using it for a while and I haven't grown two heads.
YET!
At the end of each trip empty the tank and pipes, I do this on the way home, I open the Cocks and the taps (pump off). At home I blow down the pipes/taps and wipe out the residue in the tank .
Goldenoldies
May 10, 2012
407
22,220
Portugal
Don’t own one.
Been using those so will stick with them. Thanks
YET!
Can't get into my fresh tank but thanks for the info
Will use the Puriclean down the waste pipes and tank
Jan 8, 2013
8,490
11,527
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
Including this year - never.
funflair
19,346
30,235
Guisborough
MORELO palace
since 2012
I'm thinking if I only put in clean water and keep it in the dark there will be nothing to clean, it's worked OK for the 4+ years we have owned this one and the 14 years before that we had a caravan with a fixed water tank.
So that's no I don't bother.
Martin
Angelwitch
73
50
Hornsea
Low Profile
Since 2014
Never cleaned ours either (2 years) ours lasts us 6 days ,so at the most we are drinking 6 day old water ..I think I've put aquatabs in about 4 times
Aug 10, 2008
197
183
Hawes, UK
VW California
Do not drink directly out of tank, use Nature pure filter,so not sure if it's a good idea to put anything in tank, just in case it damages filter!
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
We never drink from it (unless it's been boiled in the kettle) so make no effort to clean it.
I know some use it for drinking but we choose not to. We drink bottled water.
TerryL
6,184
8,186
North East
Low Profile
I tend to flush it out with fresh water after a long trip to clear anything we may have picked up, also after it's been in storage with empty tanks. As others though, we don't drink the tank water directly, only after it's been boiled.
Big Nick
260
290
Yorkshire
Low Profile Coachbuilt
Newbie
What he said!
Mar 23, 2012
9,545
32,093
sleights
c class
Always store it dry and refill with fresh tap water before using I figure the chloride in the tap water is designed to keep the water supply pipes clean so will be good enough for me
Fletton
1,531
2,501
Lincolnshire, UK
Knaus Sky I Plus 650LG
First MoHo - April 2015
Had Moho for 17mths from new... Just filled it with "Council pop" on first day... And I think it's only been totally emptied on only very few occasions and flushed once with H20 + whatever "they" add to it.
I always drink from it... Never purified it... sometimes fill a bottle and pop in the fridge for a cold drink of water on a hot day....
Noticed some limescale forming in "ribs" of fill pipe... So may flush with citric acid at some point...
However, to date, it's been filled with UK water only...
I have two boxes of "Stuff" from Truma in the garage to clean boiler (I think) when I get around to it.. Not sure if it's for the FW tank also..
I think I have a constitution like a waste disposal from being exposed to everything as a kid - I guess :) non of this poncy anti-bacterial this and sterile environment that... :)
Windy
3
Lancashire
MB Autotrail Dakota
3 weeks
We got our MoHo 6 weeks ago, never give it a thought to clean the tank just flushed it and drank it, as we lived on a canal boat for 16 years. never bothered to clean that tank either. Still here.
Jan 31, 2016
1,117
606
Halifax
A Class Rapido 9097F
June 2016
Remember to clean the filter. We recently cleaned out our water tank with puriclean and plan to use aqua tabs whilst abroad. We took the filter out to clean and wife almost threw up. It was bad.
Silver-Fox
9,266
29,091
Cheltenham Spa
Rapido
im a not so newbie
I always flush a bit through the system when refilling.
Never quite understood why people won't drink the water I cant see its any different from drinking water out of a bottle :rolleyes:
Nov 18, 2011
11,862
43,022
Planet Earth
A van
Over 25 year's
In the UK and Europe water contains cloren.
I clean my tank with tap water unless it Ben contaminated I have never had any problems.
After every trip I just empty and fill with clean water
Bill
