Storm123
Whats the best thing to clean the plastic windows in the motor home
Our manual (Chausson) says soap and water only, mild detergent, warm water, no abrasives
It also says to keep aerosols & hairspray away from windows as the solvent damages them. That would include air freshner
Err Yess if you use a solvent based air freshener
BUT if the plastic ones are scratched the best advice I've been given is Brasso and lots of time
"It is strongly recommended not to use aerosols near the bay windows and skylights (risk of ring formation).
These windows must be cleaned exclusively with water and mild soap. never use detergent products, including those designed for everyday use. In particular, those based on hydrocarbons or alcohol may alter window transparency and even cause cracking"
"The methacrylate glass of the panoramic windows, such as that in the living cell bays, must be cleaned only with soapy water or with special products for methacrylate glass. Fine scratches and some dull stains may be removed with polish and a soft cloth."
why no fairly liquid Charlie ? and what do you use if it says soapy waterBrass is the last thing you should use on plastic or acrylic windows. It contains ammonia which will discolour them.
Also please please do not use fairy liquid on ANY of the surfaces on your expensive vehicles.
I'm telling AshleyThe wife
Am assuming from your other thread that polish is to be used, starting with the lowest cut
My mistake Charlie, I looked at the link above, however that was for removing small scratches am the one confusedFairy liquid is not mild soap it's very aggressive and contains much salt which if it gets down your van that you have perhaps waxed will strip that wax on contact . It's way way to strong and it's horribly aggressive.
If you are doing regular cleaning of the windows.....
Swill as much dust off as you can
Them using a very mild soap like car shampoo and warm water gently clean using a nice soft microfibre towel
Dry off with another soft microfibre Bobs yer muvvers bruvver.
I thought this thread was about cleaning not polishing ? Am I confused ?
