CI Autoroller shower tray (1 Viewer)
mickthebrick
Banned
Mar 16, 2010
22
12
Leeds
Coach Built
Since 2008
Hi all, considering buying a Fiat CI Autoroller 2.8 td x reg (2000) unfortunately it has a cracked shower tray, does any one know if it is possible to replace these, are they still available, its discoloured and quite badley cracked so I don't think a repair would be possible, appreciate any help or advice
Mick
Big Ed
54
Derby
Hello OOMickOO and welcome:roflmto::roflmto::roflmto:
If you contact John Cross Motorhomes (they are trade members) I am sure they will be able to advise you.
betray
Lakes
Years and years
Hi Mick we have a badly stress cracked shower tray and have made arrangements with Branfibre of Banbury to have it re-fibreglassed etc. The cost is within reason and they can do the work in a day.
Heyupluv
3,862
1,593
France,
touring many years..42+
Mick
Mick give these a try I used to use them when I lived in England......put in Quick search Showr tray
Mel:thumb:
M
mickthebrick
Banned
Mar 16, 2010
22
12
Leeds
Coach Built
Since 2008
Thanks all of you for your help, I'll let you know how I get on,
mickt
9
SUFFOLK
LOW LINE
10 years
I have the same problem with my shower tray and have discovered Branfibre via the net. Have you had your tray repaired yet if so what was the job like please.
Jan 11, 2010
2,752
9,590
Chester
Auto-trail
shower tray
We had a problem with our shower tray, it had two drain points in the moulding one in each corner, depending on which was used they would cut out the moulding and fit the drain.
Obviously were they are shaped is a weak point and the indent cracked all around, fitting a new one was quite an expensive job plus buying the tray so i just used a fibre body filler to fill the hole and bring it up to level.
After sanding it off you don`t even notice it, cost £12 for the fibre filler and a bit of elbow grease.:thumb:
32,683
66,690
If you are going to do a fix yourselve, make sure that there is sufficient stregthening under the tray to support it and avoid it cracking again. If you can't remove it, but can get under a part of it, you could use some of the expanding foam stuff to do the job.
