Chieftain Electrics while on the move (1 Viewer)
Jo n Steve
31
10
Lincoln
C class
Hi, I'm a new member and have a 2015 AT Chieftain and would like to know if anybody knows how to modify the electrics so they work in the habitation area whilst driving as they do in the European models. I'm aware this is against NCC regs, but the van is going to be in Europe. Any advice welcome.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
It doesn't matter where you use it - no-one is going to check. It will be a relay that operates when the ignition switch is on. Unless another owner of the same van is able to say where it is it's a question of listening for the 'click' to track it down. The most likely place is part of the van habitation charger / control unit. If it is a single-function relay the easiest mod is to prevent it from operating by removing its control wire or by bypassing the pair of contacts that break the circuit. Have you approached Autotrail for a wiring diagram?
Jo n Steve
Jo n Steve
31
10
Lincoln
C class
Hi Tony
Thanks for both replies, new to this. I will try and find the click as you say. Always a bit worried of alerting AT due to warranty etc. Hopefully some likeminded AT owner will see the post.
Nov 14, 2009
425
252
normandy
c class
16 years
i did it on my scout , involved finding the wire inside the sargent and snipping it and shrink tube the bare ends. i will have a look and see if i can find the info i used . mine is a 2007 model though so could be different . you could also give sargent a call too
Jaws
23,836
72,479
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
To start with NCC regs are absolutely nothing to worry about, abide by or even consider.
If they wanna make rules then let THEIR members worry about them ! :)
To answer the OP, it is not an easy job and you will have to have some know how..
You COULD just cut the thin orange wire and put a switch in it which would stop the hab area switching out, BUT, it would also stop the fridge switching over to 12v and may well stop the hab batteries charging from the alternator .. Though I have NO idea if that would happen or not as I never tried it to be honest.
To get over the fridge switching would be easy enough using a relay from the orange wire ( feed side ) to the relay operating the fridge..
I took a view that in reality the only circuit we used regularly when on the move was the water pump. To that end I fitted a relay which over rode the cut off to the water pump.
I also added a 12v socket to the water pump circuit in to which, if it was needed, a light or indeed anything else could be plugged when on the move.
In reality that socket is used to plug in a USB charger which we have the fones and what have you plugged in to
I did post a thread with all the details and wiring diagram on here but certain members berated my efforts and generally took the pee..
I have not bothered to update the information and diagrams since but the original info is still all good and relevant..
Jo n Steve
Jo n Steve
31
10
Lincoln
C class
thanks Jaws.......i will look at tomorrow when have a clear mind, Sunday night in the local village pub!!
Many thanks
Steve
Jo n Steve
Jo n Steve
31
10
Lincoln
C class
Well, managed to sort this with the help of a friend from work. The AT Chieftain (2015) has a floor mounted fuse box located behind the driver's seat, if you unscrew the four retaining screws that hold it to the floor, underneath is a white terminal block with 8 wires coming from it (see picture). I disconnected the terminal block, cut the blue wire and put a small rocker switch in line. I drilled a hole in the side of the plastic fascia below the seat belt to allow me to switch it on or off while driving. When switched on you do have to switch the power button on on the Sargent unit again.
Fridge still works, water pump, lights, 12v sockets and toilet. Only thing that does not work is the charging of the leisure batteries.
Passengers that are strapped in can now read with the small directional LED lights while on the move. An hour from arriving at your destination just switch off to top up the leisure batteries. SIMPLES!....or it was for my friend!!
138go
3,276
14,613
Carthago 138
Since 2001
Don't know why they do it like that. One of the nicest things about the continental MH's is that everything in the back works while you are on the move. Cannot for the life of me see why you need it turned off. The SWIFT we had used a Sargent Panel and that was always a pain. SWMBO would head for the Ladies and forget to switch the water on.
Cossieg
221
98
Yate for the summer!
None now
You could wire the batteries together with a switch and fuse inline & then all batteries would charge from any source. I seem to recall someone else doing this recently. Just remember to disconnect when parked to ensure the vehicle battery doesn't go flat. You could put the switch in the cupboard next to the sargent unit so the wiring would be short.
Cossieg
221
98
None now
R
Rules is rules!
DBK
18,023
48,095
Plympton, Devon
PVC, Murvi Morocco
What an odd rule. Our UK made van has everything working when driving: heating, USB charging, lights if we wanted them. I guess the idea is to stop folk making dinner* on the move!
* Supper or Tea, depending where you live. :)
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
Our very British Swift powered the 12v socket and the spotlight by the belted travelling seats and the kids could watch dvds on the move.
Minxy
32,651
66,541
E Yorks
Carthago Compactline
Was it like that from new? It is VERY unusual for a British built MH to do that, especially a Swift! John's does it because he has a Murvi PVC so the converter intentionally allows the use of the rear electrics with the ignition on, but any of the larger British MH manufacturer's always make it so the rear electrics (other than the fridge's 12v supply) are automatically turned off on the move.
Lenny HB
53,430
149,981
On the coast in West Sussex
Hymer B678 DL
The NCC live in the past it is a reg they made up for caravans but have never re-writen them for Mortorhomes .
Reactions: DBK
Minxy
32,651
66,541
E Yorks
I've sent a message to the NCC to ask! I'll post their reply if and when I get it!
I wish you luck but IMV they're not going to go against their own 'rules'. If nothing else it may make them think about changing them though ... we can live in hope! :xsmile:
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Don't know why they do it like that..
Best explanation I've seen, money. If the hab electrics are shut down whist in motion it means they don't need to do an expensive CE scan of the hab side to prove it does not interfere with the engine etc.
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
Yes, we had a 2013 Swift escape from new and it was like that when i bought it.
The tv 12v socket could be used for charging when travelling. The spot light above worked and the kids could read/ draw in the dark.
Lenny HB
53,430
149,981
Hymer B678 DL
I think you mean EMC Electro mechanical compatability, in my last real job I was
Involved in doing EMC testing .
Cossieg
221
98
None now
Hate to be smart arse but EMC isn't electro mechanical compatability it's electro magnetic compatability! i wonder what you were doing in your last job?
