Autotrail. how to get water when the engine is running
Discussion in 'Motorhome Chat' started by Jaws, Jun 21, 2014.
  1. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,584
    22,497
    Narrfoook
    It came as a bit of a shock to the system+going from a proper Eurobox to a brit built Autorail
    Why so ?
    Because as many will know, as soon as you start the engine everything in the had area switches off..
    99% of the time it does not really matter, but the one thing we really did need was the ability to draw water whilst running ( several reasons, not the least being to flush the loo if we are on a long haul stint )
    After various false starts I decided to go back to absolute basics and forget trying to modify all the ruddy Sargent system
    So starting with what I needed to happen:
    1) I wanted the water pump to work when the engine is running
    2) I did not want a permanent live feed.
    If the water dumps that would mean the pump would keep on pumping for ever even after the water has run out !
    If a leak occurs I did not want a van full of water.
    So..
    I fitted a DPST ( double pole single throw ) relay that activates when there is a voltage coming up from the engine to the Sargent panel ( this wire is usually orange and white )
    Find the orange wire with the white tracer and 'T' off of it to one side of the relay coil
    I found the feed wire to the water pump and cut it ( on Autotrails it is usually green with a blue tracer ), putting the normal feeding wire end on one side of a 'normally closed' pair, and the other cut end to the common of that side of the relay.
    That ensured when the engine is not running the feed to the pump works as Autotraill intended and only comes on when it is switched at the control panel
    On the second set of poles I linked a wire from the from the same pole as the wire that goes to the water pump, and on the normally open side of the second set of contacts in the relay
    On the normally open contact I put a +ve feed wire ( via a 10amp fuse ) to the leisure battery feed wire.
    Lastly I added an earth feed to the relay coil
    Now, when the engine is running, the relay kicks in, disconnects the water pump feed wire from the Sargent unit, and connects a +ve feed to it straight from the battery.
    Attached is a wiring diagram that may be easier to follow than my explanation :Smile:
    Doing it this way ensured I did not 'back feed' in to the Sargent livening up other circuits which I may well not want live !
    using this method I suppose it would be easy to change other feed circuits in the same way.. to the 'entertainment centre, or the lights for instance..
    But that may be for another day.. At the moment I am just happy to be able to flush the loo whilst on the move !! :Wink:
    • Like Like x 6
    • Informative Informative x 1
  2. phase3begins
    phase3begins Read Only Funster
    Jul 1, 2012
    281
    317
    Nr Whitby
    You must have very special seatbelts:BigGrin:
    • Like Like x 4
  3. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,052
    3,452
    walthamstow east london
    a bucket would have been easier lol
    • Funny Funny x 2
    • Like Like x 1
  4. Jaws
    Sep 26, 2008
    18,584
    22,497
    Narrfoook
    Not needed on sideways facing seats so she always sits in the back in case of 'emergency' :Wink:
  5. sb8263
    sb8263 Funster
    Apr 29, 2014
    651
    331
    leeds
    Bloody hell its hard enough peeing in ours when stopped with this metal lump of a leg,,,never thought about trying it while on the move....but as wifey wont drive our MH, guess i wont be peeing on the move unless i want a wet seat :Rofl1::Rofl1::Rofl1::Rofl1:
    • Funny Funny x 1
  6. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,374
    9,819
    the other option of course would be to put a switch on the feed to the cutoff relay, which is powered from the same ignition feed. that would allow all the 12v bits in the hab area to be used with the engine running. then you could charge the laptop etc whilst driving
    • Like Like x 1
  7. Jaws
    Sep 26, 2008
    18,584
    22,497
    Narrfoook
    That cannot be done as it means:
    Either you have to switch it over every time you want water
    or if you leave it switched over then the leisure batteries do not get a charge and the fridge does not switch over
    That was actually the first thing I tried ! :Wink:
  8. Allanm
    Allanm Funster
    Jun 30, 2013
    3,117
    4,251
    Cotes d'armor, France
    I tried going to the toilet in a coach once just as it was pulling into Gatwick airport. When I came out, it looked as if I'd had a shower with my clothes on ( note, never wear khaki chinos when travelling!)
    I think I would rather stop the van than risk that again, long trip or not.
    Allan
    • Like Like x 1
    • Funny Funny x 1
  9. Jaws
    Sep 26, 2008
    18,584
    22,497
    Narrfoook
    Try sitting down ! That is what ladies do and they seem to manage without covering them selves in errrr... well ... stuff !
  10. davejen
    davejen Funster
    Aug 21, 2008
    1,248
    699
    Kirkpatrick Fleming Dumfries
    Would it not be easier to just STOP for a few mins? that's what we normally do in such circumstances!, much safer for all concerned.
    Imagine having to do an emergency stop when someone in mid-pee!
    Cheers, Dave:thumb:
    • Like Like x 1
  11. laneside
    laneside Funster
    Aug 14, 2009
    3,542
    5,502
    Oradour sur Vayres
    John why do you not apply for post of advisor at Autotrail they may start to make good vans from the start.
  12. Jaws
    Sep 26, 2008
    18,584
    22,497
    Narrfoook
    Hang on.. I simply passed on some info that I have been asked to report on if and when I came up with a solution
    Judgements on my or my wifes behaviour is neither warranted or asked for
    What you do is up to you.
    I dare say you do not do an average 500 miles a day either ( MH.. car or bike 900 to a 1000 if needs be )
    I doubt you ride a motorcycle at silly speeds on race tracks
    I doubt you jump off perfectly safe bridges attached to a bit of elastic..
    To mention just a few weird things that I might or might not get up to. :Wink:
    And believe me, if you have to do an emergency stop on a motorway the last thing anyone is gonna worry about is having to stop mid-pee, cos its highly likely that things are gonna get a lot more lively than is healthy for any one trying to haul up five and a half tonnes of motorhome in an emergency stop
    Woman does not drive and if I need a 'rest stop' then yes, we have to stop.. If woman wants the rest room then no, we do not need to stop and why would we want to ?
    If we wanna get to x point on the map that day then stopping for a loo break every 30 to 40 minutes ( yesssssss..... it really is that often not that it is any one elses business ) would add an hour on a journey or reduce travel distance by 40ish miles
    LOL !!! All in all I reckon ( contrary to what is oft posted ) the autotrail is pretty well built :thumb:
    The things that I did not like ( such as the daft tube lights that draw a huge amount of juice, and the lack of elektrickery in the hab area with the engine started ) I have pretty much sorted out.
    Since I mentioned it when we got the MH a few folk said they too would like to have such and such working in the back and its a pain..
    I post up the info ( inc a wiring diagram ) and all I seem to have got for my trouble is wellll, advice on what is safe to do..
    For those who who injected humour I thank you
    For those who offered alternatives and other ideas, I thank you
    For those that know me you will know what comes next.. :Rofl1:
    For those that do not know me and think they know better than me what I want or want to do..
    Nahhhhhhh .. cannot post it cos I will end up getting a red card !!!!!
    • Like Like x 5
    • Funny Funny x 1
  13. seanoo
    seanoo Funster
    Nov 14, 2009
    360
    215
    normandy
    hi , i cut one wire (i think the orange and white that you mention) and taped it up and everything in the hab end works now with the engine running. :Smile:
    • Like Like x 1
  14. Jaws
    Sep 26, 2008
    18,584
    22,497
    Narrfoook
    Which Sargent panel have you got ?
    When I did it I got no charge and the fridge never switched over
  15. Biggles
    Biggles Funster
    Sep 2, 2009
    151
    33
    Essex
  16. Chris
    Chris Funster Life Member
    May 5, 2010
    16,563
    35,241
    kent
    You don't need to stop Jaws.
    Just find a straight bit of motorway and stick the cruise control on.
    You can then nip back, do the business and probably have covered about 2 miles by the time you get back in the seat.
    If you think about it, that will probably save you about 30-40 minutes a day assuming you stop about 3 times.
    If you haven't got cruise I think Dave Newell does retro fits:thumb:
    • Like Like x 1
  17. Jaws
    Sep 26, 2008
    18,584
    22,497
    Narrfoook
    • Funny Funny x 1
  18. Dawn B
    Dawn B Funster
    Oct 20, 2013
    5,212
    14,655
    South Norfolk
    Gee thanks :BigGrin:
  19. Jaws
    Sep 26, 2008
    18,584
    22,497
    Narrfoook
    In that case.. SOME folk seem nice enough.. then there is Dawn :Rofl1: :Rofl1: ( sorry ! Could not resist !! )
    • Like Like x 1
  20. Dawn B
    Dawn B Funster
    Oct 20, 2013
    5,212
    14,655
    South Norfolk
    :lips:
