Chausson 2014 best of 510
Discussion in 'Chausson' started by Alonsos, Oct 12, 2015.
  1. Alonsos
    Alonsos Funster
    Feb 9, 2015
    177
    15
    Devon Somerset border
    do any of you own a Chausson best of 510 2014 ish reg ?
    If y'all do when you hook up to 240v does your engine battery get topped as well as your leisure battery or does it only feed your leisure battery only ?
  2. TG1903
    TG1903 Funster
    Oct 25, 2014
    26
    55
    N.E . Scotland
    We have a 2015 chausson 717 and the engine battery does get topped up as well , it's on the Ford chassis
  3. Alonsos
    Alonsos Funster
    Feb 9, 2015
    177
    15
    Thanks for that my base is Fiat, I spoke to dealer yesterday and my best of 510 only charges leisure batt when on shore supply 240v ,it's going in shortly to have wiring altered to cure problem X fingers it works
  4. Spidey
    Spidey Funster
    Jun 16, 2013
    839
    556
    Wiltshire
    We have a 510 2014 model never noticed if it does. Maybe i am asking a stupid question but how would you know?
  5. Alonsos
    Alonsos Funster
    Feb 9, 2015
    177
    15
    Well mine was my fault really , got 510 early August and due to circumstances weather ,wife hospital apps etc have not run van out at all + new alarm fitted feeding off battery (only Milliamps) but all batts drop voltage even with nothing switched on so nearly 3 months I thought I was charging both batts when on 240v when in fact only charging hab then went out Monday and alarm went off apparently it will do that ( deafening) tested eng batt and only 9 volts & more warnings on dash than a jumbo jet wow!! Took batt out took 2 days to get it to 13.2 volts put it back & all is sweet again so keep eye on control panel re hab and eng batt levels or how many blobs someone called them ha
    (Don't I rabbit on )
    • Like Like x 1
  6. etap
    etap
    Nov 19, 2014
    256
    233
    Somerset
    Just noticed your post.
    We bought a new Chausson this year and I asked that I wanted the motor battery to charge at the same time as the leisure battery from the solar panel because normally they don't. The motor battery from ehu normally only charges the leisure unless you have it included we didn't. Probably a bit late reply.
    Etap
  7. Alonsos
    Alonsos Funster
    Feb 9, 2015
    177
    15
    All my previous vans had facility to charge either or both but on this new one eh no cant do that ,
    Think we're going backwards @ times, anyway it's going in on Wed to have extra bit of charging kit fitted and to have my ceiling skylight looked at also (Remis) that's also faulty
    Thanks for your reply,kind of you !
  8. Geordies
    Geordies Funster
    May 29, 2013
    944
    2,139
    Tyneside
    On our bestof10, which is very likely to be same wiring as 510 models, ours is Ford based. When 240v is plugged in, the default is to charge the engine battery. To ensure the leisure battery is charging from 240v you have to put the main switch on which is on the control panel.
  9. Alonsos
    Alonsos Funster
    Feb 9, 2015
    177
    15
    My best of 510 is not like that I have just had the facility fitted £75 + I've fitted a voltmeter to actually read voltage instead of looking at the blobs on control panel that indicate volts, perhaps mine is different re it's a Fiat not a Ford
    Regards
    Alon
  10. Rogdoge
    Rogdoge Read Only Funster
    Oct 13, 2016
    4
    Colchester, Essex
    Hi Guys,
    My first post, just to say I have 2014 510 on the Fiat base and the dealer did confirm that the panel over the door must be on for charging to operate from hook up and then only charging the habitation battery. I had a battery master fitted, a little black box which monitors both batteries. When the habitation
    battery is full the engine battery receives the charge.
    I monitor voltage on both batteries while on hook up at home and it works well.
    Kind regards
    Roger
    • Like Like x 1
