Change to LED lights
Discussion in 'Motorhome Chat' started by Beachbum, Sep 30, 2009.
  1. Beachbum
    Beachbum Read Only Funster
    Sep 13, 2007
    215
    Hamburg / Cornwall
    Thanks folks for all your advice. The bulb unit is clipped on into the bulb holder. Had to pry it out gently and the unit comes away hanging on the wires. I removed the bulb and it is printed on the back, 30 degrees, 12v 10w. The bulb has 2 tiny pins. It is halogen. Question is, what wattage will I need for a LED. I would like it a bit brighter. Appreciate your advice. Thanks.
  2. cater_racer
    cater_racer Read Only Funster
    Oct 15, 2008
    46
    Chester
    LEDs are not famous for "Brighter".
    Try a 12v 20W ???
  3. hilldweller
    Dec 5, 2008
    26,871
    25,734
    Macclesfield
    Wattage has no meaning in LEDs because the efficiency varies from type to type. Just go for the most powerful that will fit - this is usually one with 4 LEDs not one with 10 because the 4 newer LEDs will be better than the old round packaged LEDs.
    Your main choice is Warm White or White. I prefer warm but the starker plain white will look brighter. You'll only get a similar brightness to the 10W bulb bit burning only 1W.
  4. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,700
    17,315
    YO11 2BD
    i have both 20 and 25watt leds and they are both brighter than the original 10watt halogens.
  5. Munchie
    Munchie Funster Life Member
    Jul 28, 2007
    8,571
    11,754
    Champagnac-La-Riviere
    Agreed our LED's are brighter than the halogens we had in. :Smile:
