CBE CSB-2 battery charge relay operation. (1 Viewer)
Plinky
44
6
UK
Westfalia James Cook 2004
Newbie
Hi,
I've installed a CSB-2......I think I have done it correctly, but am not getting a lit LED. Does this just come on when charging of the starter battery is activated or should it be lit all the time once the device is installed correctly?
Thanks for any help.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
It will only light when it senses 13.6 volts. So it will not transfer charge until your solar has pushed the voltage up
Techno
Jul 28, 2010
15,475
20,756
May 2010
SPECIFICATION
Up to 4A charging of your engine battery
* Engine battery will automatically start charging when the Leisure battery voltage exceeds approx 13.6V
* The Engine battery will not receive any charging when the Leisure battery drops below approx 12.5V. This ensures your leisure battery receives priority charging whilst camping etc.
* The green LED indicates that the Engine battery is receiving charge.
* W 74mm x D 49mm H 44mm
* Instructions supplied
* Manufactured & CE marked by CBE
P
Plinky
44
6
UK
Newbie
Thanks Andy, thats a relief, I was worried when it did not light that i had made a mistake. I'm still waiting for decent sunny weather....its done nothing but rain for days. :(
Dec 2, 2010
1,060
2,321
Hollywood, Birmingham.
A Class Laika
Since 2011
Plug in an EHU lead, when leisure battery reaches 12.6V the green light will come on, it does on mine. Thanks to Andy(y)
P
Plinky
44
6
UK
Newbie
Thats a good idea, thanks :)
P
Plinky
44
6
UK
Newbie
I just plugged in the EHL and i registered 13.4v for the leisure batteries on the screen of the vans main control unit. But, the csb-2 green led light came on, so i think its probably working ok and the van readout may not be so accurate.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Probably the start up voltage of the charger peaked over 13.6 after which it will continue to transfer charge until down to 12.5
So if you switch your charger off now and watch the voltage fall it will confirm it is working to spec so it cannot discharge your leisure battery
P
Plinky
44
6
UK
Newbie
Thanks Andy, I've had it turned off for a while and the voltage was down to 12.8v with the green led still lit. When i put a load on the leisure batteries just now by turning on the diesel heating, the green light clicked off.
