Seems a bit OTT, they could have just issued a notice not to be sold without updated instructions.
Appears nothing wrong with the heaters just need to use common sense when installing them, I suppose they have to protect the idiots.
The heaters appear to be fine. Just instructions crap (not exactly unusual for Chinese stuff)
Expensive to print new instructions.I was looking again yesterday at some I had on “saved” and they’re going up in price, hard to find one for less then £125 now and most £130 for a 2kw one. Only a few weeks ago they were around £95-100….
also known as " scamming bastards r us"I was looking again yesterday at some I had on “saved” and they’re going up in price, hard to find one for less then £125 now and most £130 for a 2kw one. Only a few weeks ago they were around £95-100….
The problem is that common sense was never very common.I mourn the death of common sense, may it rest in peace.
But we do accept it time and time again, OK this shipment was stopped but most likely just the tip of the iceberg.Made by child or slave Labour working hours that we would not accept, in conditions that we would not accept, with quality control we would not accept
Crush the lot
Absolutely, but I think you should have qualified your "we would not accept" comments with "at the moment" . . .Made by child or slave Labour working hours that we would not accept, in conditions that we would not accept, with quality control we would not accept
Crush the lot
Searching for drugs is not the function of Trading Standards officers.Let's hope that they missed finding the stash of drugs while they were protecting us all from the dangers of Darwinism
Why do people buy these
You are lighting a small fire in a confined space to heat a very expensive living quarters, which in turn contains air that you rely on to be fit to breathe
I’ll take my chances with a reliable source
No different to Truma or Alde heating then so by your statement all gas and diesel heating should be removed from Motorhomes.Why do people buy these
The Australian guy who is pretty much an expert on them did some measurements on them and the exhaust was incredibly clean.as an aside, we also have a zibro type paraffin heater, which is certified for use indoors in a well ventilated area. the products of combustion are deemed safe enough to just be released into the room. if a 'diesel heater' was also fired by paraffin, i wonder how the exhaust fumes would compare?
I take it you are not suggesting that Truma and Alde systems have not documents of conformity as well.No different to Truma or Alde heating then so by your statement all gas and diesel heating should be removed from Motorhomes.
i did suspect that to be the case, but have no knowledge of the fact.The Australian guy who is pretty much an expert on them did some measurements on them and the exhaust was incredibly clean.
I was referring to this statement "You are lighting a small fire in a confined space to heat a very expensive living quarters,"I take it you are not suggesting that Truma and Alde systems have not documents of conformity as well.
You need to understand how these heaters (and every other gas or Diesel fired heater) work. At no time is the "air that you rely on to be fit to breathe" in contact with the combustion process.Why do people buy these
