Carioca 656 control panel (2 Viewers)
Cat
5
North yorkshire
Fiat ci Carioca
Have disconnected my battery and now control panel doesn't work. Anyone had this problem before?
Dave
656
1,052
290
The universe
If you speak to Steve Smith at Autotrail (01472 571000), he will send you a PDF of the user manual for your control panel.
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
It wont with battery disconected
C
Cat
5
North yorkshire
Fiat ci Carioca
Sorry I should have put once I reconnected the battery the panel wouldn't work :)
rainbow chasers
3,680
1,725
Mid Cornwall
Various
Check the fuses on the hab side of the main battery, and the leisure battery fuse, which will be nearby, but not in the battery box - you probably had a surge pop the fuse when you reconnected.
For the leisure one, look under the seat near the battery area - they are usually screwed to the floor.
656
1,052
290
The universe
All the fuses fpr the Hab area are in a box behind the drivers seat. Well, they are in my 656.:ROFLMAO:
C
Cat
5
North yorkshire
Fiat ci Carioca
Thanks everyone, have checked all fuses and all ok. Have just ordered new control panel from Italy so hopefully that will solve the problem ;-)
Dec 6, 2011
11,596
25,450
South Wales
Coach built Adria
Dont hold your breath on it coming any time soon. I HAD A CARIOCA 746 took 3 months for a bumper part to come and 18 months for a habitation door to arrive.....:Doh::cry:
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
I had Control Panel/Fuse Board problems in my 2005 reg 656, and in the end, after various attempts by various people, I had it all sorted by Geoff Cox of Derby, who are the CI dealers whom we bought the MH from. In my case it was to do with inaccurate monitoring of the engine battery and I needed a new fuse board, which cost ÂŁ200 plus labour.
I'm not sure which year your 656 is but have you looked under the driver's seat in front of the charger to see if the in-line blade fuse is OK? At one point mine managed to blow.
Might be worth checking whether or not your fridge works on 12v with the engine running, and whether your blown air heater fan is working. Your fridge is dependent upon the fuse board behind the driver's seat, and my heating fan is independent of the control panel, so I'm assuming yours might be too. If neither of those were working the problem may not be in the Control Panel itself, which is a fairly simple component with a few lights and switches on it. The actual controlling of the electricity supply is done by the fuse board, which is far more complicated.
