Carioca 635 (1 Viewer)
lee79
6
kent
ci
since 2004
I have a 2005 Carioca 635 which so far has been good as gold but recently the water pump does not turn itself off when it gets up to pressure.When the pump button is pressed on the control panel above the door the pump turns itself on but will not automatically switch off it carries on ticking.
Any ides? I assume the pump has a built in pressure regulator which has given up
2,338
10,141
more likely a leak somewhere, dripping tap, shower head, pipe joint etc.. check that first .
the pump does have a pressure switch built into the end of the pump but rarely go wrong .. the cut off pressure can also be adjusted , there is screw on the end of pump .. IIRC screwing in , (clockwise) increases the cut off pressure.. and visa versa.
L
lee79
6
kent
ci
since 2004
Cheers mate,
Checked for leaks and the usual but all seems ok
Jun 30, 2010
7,924
27,229
1992 VW Auto sleeper Mono
Since 2005 this time
Could it be your Dump Valve is open? Happened to me!:winky:
656
1,052
290
The universe
My 656 pump did that, and it was a leak. Look outside the van for tell tale drips.
L
lee79
6
kent
ci
since 2004
Checked for leaks and it is dry
Nov 30, 2009
6,547
149,007
Pickering
PVC the PUG
Ours did the same thing when we first bought it. Turned out to be the outside shower hose attachments bit next to the water filling part inside the flap.
It was below freezing one of the first times we used her and you could see a frozen trickle. That's how we found it.
Only a slight trickle , but enough to set the pump off intermittently.
Ralph soon fixed it , adapted it to take the electric pump to fill her up with water from an aqua-roll. :thumb:
suavecarve
7,556
38,975
Surrey/Hants
Rollerteam 685
July 09
If it is a fiamma pump there is a small allen key adjusting screw underneath (actually on top but fitted upside down) if you adjust it either clockwise or anticlockwise (roughly no more than half a turn as it is quite touchy) then you basically adjust the pressure at which you would like your pump to turn off after you have used your taps/shower.
Shockingly enough same happened to me in carioca 625 and luckily father in law knows about these things, so dont thank me thank my father in law
