can I fit spare wheel under van? (6 Viewers)
june123
350
134
Staffs
Burstner A class 3 berth
since 2004 caravans before that
We have a Burstner 2009 Viseo (3 berth with "garage").
Carrying a spare wheel in the garage makes it difficult but not impossible to fit in our two bikes. Does anyone know if the spare could be fitted underneath this type of MH?
Roryboys Dad
631
805
Glapwell Derbyshire
Pilote Reference P716 LPR
This might be a silly question but can't you fasten the bikes to the rear of the Burstner and give you more space in the garage for the spare wheel - and other items?
:france::france::france:
J
june123
350
134
Staffs
Not a silly question at all but did not want the extra length a bike rack would entail and also wanted an easier way for elderly partner to store bikes.
I wish my spare was in a garage. To get mine I have to lie full length under MH and struggle like mad, you don,t know you're born. In the rain this would be torture.
rikfos
315
199
hereford
If you have got a garage leave the spare in it.
Climbing underneath the van is a pain in the A.. e!
J
june123
350
134
Staffs
In our years of motorhoming we haven't had a puncture so hope not to have to lie under MH. Anyway - isn't that the breakdown mechanic's job ? Hopefully would have time for him to turn up.
Apr 13, 2012
5,545
18,776
Mobilvetta Euroyacht
1996, then break 'til 2011
I've an older Burstner 615 with spare underneath
I'm pretty sure in the handbook it advises that you do not change the spare yourself :Doh: - I'd leave it in the locker and if I had a puncture phone recovery and put the kettle on:thumb:
J
june123
350
134
Staffs
Thank you - I agree. Is there plenty of space for driviing over road humps with the tyre underneath. We do go slowly over these. Also what sort of people can do this job? Must it be a Burstner dealer?
Sep 23, 2007
1,710
1,970
Leicestershire
4 and many as a tugger
There a guy selling the carriers on ebay. They are the later type
that dosent come loose.
£125 inc post, there are a couple of different types but his advert says tell him what Motorhome you have and he will supply the correct one.
Andy
Daveo2006
1,164
998
kent
Apache 700
3 years
This post has jogged my memory as keep meaning to try out the mechanism on our ducato,I think it somehow winds down with the use of the wheel brace kit?
32,673
66,651
Do NOT assume you can put a spare wheel under your van, it will depend on what space is available and, more importantly, what may be in the way to prevent you doing this! I looked at doing a similar thing when we had our Chausson Flash 04 and never managed to sort it as it wasn't straightforward at all, so it ended up living in our garage too.
You'll really need to have a good shuftie under your van and see if you can identify a suitable place for the wheel so that it can be attached, and removed, quickly and easily, and that it's placement which won't create issues with other bits and pieces and also won't cause grounding problems either. Good luck! :Smile:
43,348
49,550
Don't know if it's an alko chassis but it's a Fiat base
my last fiat base (2001) had an Alko spare wheel frame attached right at the rear of the chassis.
the wheel fitted between the chassis side rails out of the way.
a pain to get at but could be lower from a kneeling position.
the mounting holes and securing hooks should already be in the chassis.
not a very clear picture but you can see the securing chains and hooks at the rear and the carrier was just a heavy wire frame pivoting at the front..
11,847
14,082
How about fitting the spare to the back wall (like some 4x4s). A very few MHs have this arrangement, which makes the spare easily accessible. It can always have a cover to improve the look.
My MH does not have a spare at all, and though I would like to have one, do not really have the spare payload.
J
june123
350
134
Staffs
spare wheel
Thank you. I hadn't thought of that. It is another option and wouldn't extend the length as much as two bikes on a bike rack. The wheel is very heavy though. The back wall may not take the weight.
happypre65
137
53
Can i fit a spare wheel under the van
Hi,The problem is that unless you are very fit and good at lifting heavy wheels,and then as they say never try to jack it up yourself,the back wall is not a good place to put it as will cause stress on the body panel,i would keep it in the garage keeps it clean and easy to get too,also keeps the weather off of it and it does not suffer from cracks in the walls of the tyre,a bike rack is not that big easy to use can be fitted to a tow bar if wanted then you can take it off when not in use,fiamma bike rack on ebay most days,hope this helps you H ::bigsmile:
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Quite possibly
