Camper & Computer novice!
Discussion in 'Introduce Yourself' started by eves_granny, Apr 13, 2010.
  1. eves_granny
    eves_granny Read Only Funster
    Apr 13, 2010
    near Chester
    I'm learning,but not fast enough and am lacking the confidence to get out there in my 'old lady'JIL(Irish reg) tho' we have been to Mull.My big problem is that in my ignorance I didn't drain the water heater so that parts are needed which I'm told are unavailable-am also told that this type of heater is now illegal.I'd really welcome some pearls of wisdom from some of you experienced,knowledgeable folks.:Doh:
  2. chatter
    chatter Read Only Funster
    Aug 3, 2009
    3,723
    939
    cheshire
    Hi and welcome to the forum,
    I hope you get sorted soon and out on your travels, but i think it would be a good idea to post the make/model of water heater and the make /model of the motorhome then some of our more experianced folk might be able to give you some pointers, as there will be quite a few different heaters used in motorhomes over the years
    maggie
  3. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Hiya and welcome,
    Please give more info or post a pic of the unit.
    I replaced my water heater for a very similar one which wasn't too much bother.
    The original was 30 years old.......:RollEyes:
    Always get gas appliances checked out or connected up by a certified gas specialist before using.Venting must be correct otherwise there's the danger of noxious fumes.:Eeek:
    Steve.
  4. nannyjan
    nannyjan Read Only Funster
    Mar 22, 2010
    126
    51
    Forest of Dean, Glos
    Hi eves-granny, Just got my first motorhome and joined motorhomefun. It is all a little dauntying initially but great fun learning. Welcome and enjoy,.
    Keep Smiling nannyjan
  5. bald eagle
    bald eagle Read Only Funster
    Jan 30, 2009
    528
    4
    here,there and everywhere
    how eves_granny and:welcome:
    regards
    bald eagle:thumb:
  6. Doodlebug
    Doodlebug Read Only Funster
    Jan 28, 2010
    140
    Surrey
    Hi and welcome.
    :BigGrin::BigGrin::BigGrin:
  7. eves_granny
    Apr 13, 2010
    near Chester
    Water heater
    :Doh::Doh:The problem water heater is a Vaillant dating from 1990.I did get my gas system checked out but have a feeling the engineer (if that's the right term) used is more used to modern vehicles.All your supportive responses are mmuch appreciated.
    Just had a lovely jaunt to The Plassey,Eyton,Nr. Wrexham with my grandaughter.I look forward to visiting simpler locations when on my own.
  8. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Glad you're enjoying the "bus"....
    What a lovely weekend out just for a change....:BigGrin:
    I take it the Valiant is wall mounted.....and well vented.
    Loads of parts on here.....Might be worth giving them a call for advice...
    http://www.leisureshopdirect.com/caravan/gas/vaillant_water_heater.aspx
    Is it similar to this unit? http://cgi.ebay.co.uk/Valiant-Mag-125-G25-Tankless-Lpg-Caravan-Water-Heater-/170450392364
    There were quite a few equivalent units on fleabay new last year...Best buy new or get professional advice first.
  9. Sundowners
    Sundowners Funster Life Member
    Oct 30, 2007
    2,350
    1,439
    Suffolk
    Hi-----you have found the correct place !!!! welcome
    Is it safe to assume that the 'frost damage' has caused a water leak ?? Or does the heater just--not heat??
    I am far from being an expert, but I would imagine that the main damage would be an 'exploded' tank ??-----Or pipe/joint
    Nigel & Pamala
