Camos Flat Sat
Discussion in 'Motorhome Chat' started by Snitrats, Sep 4, 2011.
  1. Snitrats
    Snitrats Funster
    May 13, 2011
    498
    211
    Groby Leicester
    Just purchased on the internet a Camos Flat Sat @ £348.99. I think that is a petty good deal?
    £51.00 cheaper than most places.
    I am sure someone will come back and tell me where there is a cheaper one!:thumb:
  2. steveclecy
    steveclecy Read Only Funster
    Jun 10, 2009
    885
    582
    Wirral
    Looks a pretty good deal to me. Are you going to share with us where you found it?
    Steve
  3. callumwa
    callumwa Read Only Funster
    Jan 16, 2011
    4,113
    4,518
    Tyne & Wear, sometimes..
  4. chatter
    chatter Read Only Funster
    Aug 3, 2009
    3,723
    940
    cheshire
    is it the camos sat or the camos sat plus that you have got, that is a good price have been looking at the camos sat plus with which you can supposedly get the astra 2 signal down on the med but that was over 500 pounds. I like the idea of the low profile and no arm with lnb to go wrong
  5. Snitrats
    Snitrats Funster
    May 13, 2011
    498
    211
    Groby Leicester
  6. callumwa
    Jan 16, 2011
    4,113
    4,518
    Yeah, decent price. I'm thinking of getting one,
    just very very nervous at the though of fitting it myself..... drilling holes in the roof and all that:Eeek:
  7. Snitrats
    Snitrats Funster
    May 13, 2011
    498
    211
    Groby Leicester
    Have a look at campervanstuff, £484.00:thumb:
  8. Snitrats
    Snitrats Funster
    May 13, 2011
    498
    211
    Groby Leicester
    Me to go again to campervanstuff ,as well as the standard instructions, there is at the bottom of the camos listing there is a full install guide, gave me the confidence to bang a 38mm
    hole thro' the roof:thumb:
  9. callumwa
    Jan 16, 2011
    4,113
    4,518
    I looked at that along with these instructions.
    http://www.roadpro.co.uk/images/pdfs/Camos Crank-up system installation and use.pdf
    I'm still nervous about the hole for the cable never mind the 38mm hole for the dish.........:Eeek::Eeek:
    • Like Like x 1
  10. Snitrats
    Snitrats Funster
    May 13, 2011
    498
    211
    Groby Leicester
    The cable can be set to the side of the dish,although the instructions show it to the front. So
    I was going to drop mine through onto the wall cabinets and cable it to the TV point.Hopefully
    I can fix this by accessing through the roof vent. Any way hope to fix it when it arrives next week, will keep you posted:thumb:
    • Like Like x 1
  11. callumwa
    Jan 16, 2011
    4,113
    4,518
    Did you manage to install the dish without any problems?, :thumb:
    and if so how is it working, signal strength, is it effected by the wind, etc.....
  12. peter marshall
    peter marshall
    Mar 5, 2009
    2,702
    1,701
    Cleveleys,Lancashire
    Hi Chatter
    Where about's on the med do you mean, I go to Spain around La Manga and Valencia areas. Pete:Smile:
  13. chatter
    Aug 3, 2009
    3,723
    940
    cheshire
  14. Snitrats
    Snitrats Funster
    May 13, 2011
    498
    211
    Groby Leicester
    Yes ,Quite easy.once you have got the nerve to start drilling! Fed the cable to the side straight to the inside of the wall cupboard so all cables are out of sight. Does it work well? Yes sat here in Skegness at the moment 80% signal 70% quality. Setting up is a little frustrating the first time (trees) but got it down to about a minute now. Going back to fitting ,you may have to cut the elevation handle a bit shorter depending on the thickness of the roof (this is not shown on the instructions) Only downside I have found is trees, been to 2 sites last week and could not get a thing without moving the van I now find looking at dishpointer.com helps me find a good pitch before arriving on site:thumb::thumb::thumb:
    • Like Like x 1
  15. dshague
    dshague Funster
    Aug 22, 2007
    916
    187
    sth yorks
    if you don't want to fit yourself on the roadpro web site they have approved installers in your area ,
Similar Threads
  1. bernardfeay
    14
    336
  2. DAVWOD
    4
    306
  3. big dave
    9
    380
  4. Melian
    280
  5. Zajacp
    7
    708
