Camera cable entry into cab (1 Viewer)
Sep 24, 2013
1,317
752
Norwich
Carthago A class
Since 2014
II've figured out where the wiring is going to go behind the dash but need some advise on how to get the cable from under the MH to inside the cab. Any convenient grommet holes available? Can I use some acces from the engine bay or do I come in through a locker floor then along the cab floor. Interested in how other funsters have done it.
Oct 20, 2010
2,248
37,617
Burry Port South Wales
Since 2003
Took mine through the upper lockers, behind the control panel above the hab door, into the cab door frame inner space, and down the front pillar and into the dash area under the glove top glove box, took quite a bit of fishing with pull throughs and old steel coathanger a few fffing moments but worked out well, (y)
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
There is no definative easy way as every van is different. There is no shame in running along the chassis it can save a lot of messing about inside. No one size fits all!
tambo
874
639
Dunfermline fife scotland
a class
How are you getting the cable from the camera down to floor level?
If it's inside then surely better to keep it inside to the front
Never seen a cable running down outside
Techno
Jul 28, 2010
15,475
20,756
May 2010
Many vans have a garage or a wardrobe at the back so it is easy to drop through the floor and away you go. Like I said there are very many different options. It's not clear cut to say inside is easier.
tambo
874
639
a class
The op asked for advice we're simply offering it ....if drilling a hole in to the van to put cable inside I'd keep it inside rather than drill another hole to take it out again where it's open to the elements whether that be through overhead lockers existing cable channels or under bed units kitchen units etc ......
Of course it is my opinion but that's what he asked for ....i never said it was easier I said it would be better and as few converters run a the electrics under the van I'd say it was a common thought.
Techno
Jul 28, 2010
15,475
20,756
May 2010
It's easier to run inside during construction for sure
stevec
Sep 24, 2013
1,317
752
Norwich
Carthago A class
Since 2014
Thanks for the advise everyone. I have an end kitchen layout and no panelling over the door. I had planned to take the cable through the rear top cupboards, down the corner of the MH and through the corner of the drainer. Then through the lower cupboard and through the floor. Along the chassis and up through the cab. I must admit to not having considered running it inside. I recon it may be do-able if I can get it past the door. I'll check that out tomorrow. It will mean drilling a lot of holes which I had hoped to avoid. Thanks for the suggestions.
Kool Kroozer
1,361
2,228
Cannock Staffordshire
Low Profile Hobby Premium
Always learning
Our cables run from the back of the underneath all the way to where the cab is, under the drivers step there is a grommet - you can clearly see it if you get down and have a look - just remove the plastic trim covers that are inside the foot well and the cables have been fed through there and run up along/behind the rubber that seals the door frame then the cables branch off to the fuse box - Watching the auto electrician do this made me think - "god that was simple", but i suppose its what you know, I am pretty sure if cameras had to be fitted again i could do it myself (y)
Dec 12, 2010
5,427
21,681
Cumbria
Was going to be impossible to run my cable inside the van, went underneath along a chassis rail and back into the cab via a drain hole in the vehicle battery box which sits under the floor between the front seats.
