Cadac safari chef - connection?
Discussion in 'Motorhome Chat' started by gowboy, Jun 18, 2012.
  1. gowboy
    gowboy Read Only Funster
    May 26, 2011
    44
    7
    Ludlow
    seen previous threads re:Cadac safari chef - fancy it, tracked down best option - just unsure of correct connection to existing external outlet (LPG) on my van: gather it needs to be low pressure bbq unit, gas already regulated on Gaslow set-up so no need for regulator (?), but what sort of connector do I need from the hose to attach to the gas outlet valve? Could do with being armed with correct MHFun info before entering scary gas-fittings section of shop!
    Thanks in advance:Smile:
  2. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,685
    5,837
    Mansfield,Notts
    As there are a few different makes we need a make or better still, a pic of what you have already:thumb:
    see if you can see yours HERE
    Thats assuming you are talking about an external BBQ point
  3. gowboy
    May 26, 2011
    44
    7
    Ludlow
    Thanks Geo - pics attached, it has warning stickers in German btw - outer casing has "KAMA" manufacturer detail on it.... the outlet looks like it has a sliding collar that should shift over when connector inserted (?)- then the red gas valve will twist open (?)(sorry not v technical, I'm crap with all things gas). Thanks again.
  4. Philb
    Philb Read Only Funster
    Aug 3, 2011
    37
    6
    Carmarthen Wales
    Same as mine, double male bayonet, all caravan accessory shops stock them..
  5. gowboy
    May 26, 2011
    44
    7
    Ludlow
    yup got it sorted, thanks for your help!:thumb:
