Cable Size Info Please
Discussion in 'The Beginner' started by IanF, Apr 5, 2015.
  1. IanF
    IanF Funster
    May 7, 2013
    2,200
    650
    Redcar- N.Yorkshire
    I want to install a 12 volt socket,fused and directly off the leisure batteries and a second leisure battery. The socket will be within 1M of the batteries. Load normally 25mA.
    Also battery to battery cable size please -they will directly beside each other.
    Just wish I could remember my whole one year of electrical engineering study some 40 years ago but I can't!(sound like Orville!)
    Help please with cable sizes and appropriate fuse!
    Thank you in advance
    Ian
  2. Zains Pops
    Zains Pops Funster
    Sep 10, 2013
    734
    4,741
    Chelmsford Essex
    Are you sure of the 25mamp load. It is exceptionally low to be concerned regarding cale size..
    • Like it Like it x 1
  3. scotjimland
    Jul 25, 2007
    28,939
    25,628
    • Like it Like it x 2
  4. IanF
    IanF Funster
    May 7, 2013
    2,200
    650
    Redcar- N.Yorkshire
    Yes it's simply to run an electronic mouse repeller and that is it's stated load
    Ian
  5. IanF
    IanF Funster
    May 7, 2013
    2,200
    650
    Redcar- N.Yorkshire
  6. scotjimland
    Jul 25, 2007
    28,939
    25,628
    wet string.. ;)
  7. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,496
    6,481
    West Sussex
    As long as the fuse is a lower rating than the cable, for your use anything will do.
  8. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,958
    12,241
    Plympton, Devon
  9. PeteH
    PeteH Funster
    Nov 22, 2007
    2,216
    2,761
    East Yorkshire
    That is an ESSENTIAL. IF connecting batteries to form a "Bank" the cable BETWEEN batteries Must be adequate to conduct the maximum current. otherwise a "Big Draw" from one could cause the connecting cable to overheat (a Bit like your Toaster) With potential for Fire and or explosion.
    Pete
  10. IanF
    IanF Funster
    May 7, 2013
    2,200
    650
    Redcar- N.Yorkshire
    Was intending using 25mm cable for this the batteries will be immediately together. Will this be ok?
    Thanks Ian
  11. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,112
    17,779
    YO11 2BD
    Wire the socket for its full potential....10 or 15amps depending on type bought.
    Doing that you are then covered for any eventuallity.
    1 mtr from source should be ok in 1.5mm or 2.5mm cable
  12. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,757
    10,175
    25mm2 cable would be suitably oversized for most motorhomes, however you need to fuse the positive in case an accident allows it to short to ground. also buy the cables already terminated for you unless you have suitable crimping equipment.
    having said that, the most common battery cable size is 16mm2 and will handle up to 110amps. tonnes of these on ebay £3<. again it needs to include a fuse for safety if long enough to touch earth if it became disconnected
  13. IanF
    IanF Funster
    May 7, 2013
    2,200
    650
    Redcar- N.Yorkshire
    Thank you for this--- really appreciate the kind help you and the others on this great site freely provide
    Ian
  14. IanF
    IanF Funster
    May 7, 2013
    2,200
    650
    Redcar- N.Yorkshire
    Can I ask if I've got as planned two 110 amp batteries what size should the fuse be?
    Thanks Ian
  15. Moodybrook
    Moodybrook Funster
    Jul 7, 2013
    797
    647
    Wet and cold place outside of M25
    I have 20A on mine which should prevent too much excitement happening when I don't want it to. I also wanted to limit the juice floating about and protect my Solar controller which is a 20A jobbie.
    I believe 25A is the standard.
    We are talking about the Positive between your two batts !
  16. PeteH
    PeteH Funster
    Nov 22, 2007
    2,216
    2,761
    East Yorkshire
    To be fair. I am not sure I personally would bother, so long as the Cable can cope with the Current draw. Say 16mm2? or above. Care whenever removing a cable and disconnect the Earth(s) first before working anyway. and you should be OK.
    However. Any Fuse in the Main cable from the battery bank should be sized to cope with the Normal Current and the Surge current when a large item is switched on.
    The fuse rating In my Winnebago is 50Amp supply to the coach distribution box, according to the Wiring Diagram.? But I would caution that only as a Guide?
    If you want High capacity Fuses and Fuse Holders Try:-
    http://www.12voltplanet.co.uk/fuses-guide-uses.html
    And:- http://www.12voltplanet.co.uk/midi-strip-link-fuse-holder.html
    Pete
  17. laird of Dunstan
    laird of Dunstan Funster Life Member
    Feb 15, 2015
    1,305
    3,569
    lincolnshire
    the fuse should be sized to protect the cable , if the socket is 5a or what ever, run the correct size of cable and fuse it to that size , the fuse in the plug that feeds the mouse scarer should be sized to protect that .
  18. TheBig1
    Nov 27, 2011
    7,757
    10,175
    the above posts about cable and fuse size refer to the battery bridge cable. the size of this depends on maximum rated current of attached equipment. generally people go with 25A unless there is an inverter or B2B charger fitted
  19. IanF
    IanF Funster
    May 7, 2013
    2,200
    650
    Redcar- N.Yorkshire
    Thanks that's great
    Ian
