Buying Gasit Bottle.A coupleof questions. (2 Viewers)
Sep 25, 2009
794
1,386
south yorkshire
coachbuilt
since 2004. Tugger 10 years on and off
Hiya Folks.This may seem like a daft question but,Reading past articles,I notice that on the first fill it seems 85% fill is the start.I am fitting a 11kg bottle and a outer fill point so i dont have to open locker to fill up.How do you know when it is full,do you set the pump to a specific amount or do i stll have to open locker to read the cylinder guage.Also I have a automatic changeover regulator.Can i connect a 6kg calor bottle to one side of regulator and Gas it on other side..Any other help would be apreciated.
43,331
49,467
The bottle has an inbuilt 85% full cutoff valve.
It should be impossible to fill past 85% unless the valve is faulty.
When its full the pump will slow to a stop or may judder indicating it cant get anymore gas in.
You cannot pre select an amount as you have to constantly press the button on the pump to continue dispensing gas.....let the button go and gas flow stops....a dead mans button for safety.
Whether you fit a pair of refillables to the changeover valve or one of each is your choice....it works the same way.
Masman
Sep 25, 2009
794
1,386
south yorkshire
coachbuilt
Thanks for quick replies(y)..Questions answered.:)Anyone have any more usefull info ideas please post
May 31, 2015
11,684
44,533
Cornwall
Ducato PVC
Getting Better
80% not 85
11kg should take 22 litres
on first fill LET GO at 22 litres if it doesn't stop
And what's the average on a used empty Andy ..? Asking as I've not filled mine yet..
Judge Mental
Sep 2, 2009
6,650
5,883
Sarth London
Possl 636 FR panel van
1994 and beyond...
Yes they are cheap do a good job and work well. The fill meter stays high for ever then starts to drop away suddenly.oh! support 1st class :)
R
Robert Clark
Don't forget to close the valves on the top of the bottles when filling, or you may damage your regulator
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Not sure I like an auto change over using a standard bottle along side a refillable bottle
what happens if the user forgets to shut down the standard bottle and fills anyway
regulator damage aside, any danger of the standard bottle being over filled beyond 80% as it has no cut off valve?
resulting in liquid lpg being delivered to appliances
Zigisla
2,580
3,106
Gosport, Hants
Sunlight A72
Getting better month by month.
As the auto change over v/v only works in one direction at a time, I am sure you cannot backfill through the auto v/v.
