Burstner payload increase (1 Viewer)
Aug 30, 2012
4,270
11,305
Home of the war horse
burstnar T640
Hi all
I have a burstaner T 640 Marano 2008
And we are curantly running overload on gross weight
After peterbrough show I ran on to a axel weigh at Leeds just to check
And we were 60 kg overloaded
The van is rated on plate at 3.5 ton
But the combined axel weight shown on plate allows about 3.8 ton
So is it possible to update the plate to show a higher load without modification to brakes tires Ect
If I do need any mods what are they going to be
I have done a bit of research on net and its a bit confusing
I THINK some of the manufactures deliberately down rate to 3. 5 tonne to come into to EU regs for licensing and possibly local tax rules and as well this age 70 ruling for medical to retain higher cat on uk license
Many thanks for any info and if its been coverd somewhere else please point me in right direction
Xabia
1,186
821
Rural Nottinghamshire and Spain
Since 1996
Hi all
Had my Hymer uprated from 3500kgs to 3850kgs by http://www.svtech.co.uk/.
Extremely easy and cost from memory about £250.
Mike
laneside
Aug 14, 2009
2,668
6,276
Oradour sur Vayres
Rapido V66
nowhere near long enough
You really need to know your axle loadings first as you may be like my Rapido that has a 2000Kg maximum on rear axle which is impossible to achieve. I am always under on the front axle but the back is where the storage is and as yet I am not sure uprating changes the rear axle maximum but like you am currently investigating
Peter & Elaine
Aug 30, 2012
4,270
11,305
burstnar T640
I don't need to increase axel loads just gross load as I understand it my axels are capable of load its just down rated to get 3.5 tonne
Aug 29, 2010
845
1,251
Nuneaton. Only when I have to.
Hymer Exsis t564
Since Sept 2010
Just contact SVTech and tell them exactly what you have and, ideally, what you would like to achieve. They are extremely helpful and knowledgeable. Some upplatings are simply a paper exercise and others require modification like rear air suspension and/or a change of tyres. In all cases you will have to advise the change to the DVLA when going above 3500kg to get a new V5c issued and new tax disc. Best to act soon before the regional offices close! :Smile::Smile::Smile:
Mel
2,131
2,810
De Haan Belgium
Caravan LMC
Since 2010 Caravan since 1995
And dont forget if you go to France.
You will have to reduce your speed over 3500kg.
+ You need stickers with the new speed limits on the rear of the MH.
A lot dont bother but its €90:00 if you get stopped.
Ivory55
6,017
14,534
North West Norfolk
Since Feb 2012
hi also over 3500 kg is next step up in emissions charges for London so will mean euro 5 or what ever they are up to now. in case that affects your plans. cheers ivory55
Aug 29, 2010
845
1,251
Hymer Exsis t564
Since Sept 2010
I am now shown at 3850kg on the DVLA vehicle check site and yet when I used the search tool on the LEZ site last week it still had me down as exempt. My van is Euro IV compliant, so presumably the LEZ number plate recognition cleared me when I strayed about a kilometer into the LEZ near Bromley on the A20. :Smile::Smile::Smile:
Ivory55
6,017
14,534
North West Norfolk
Since Feb 2012
hi was not sure of exact weights but knew they wanted newer engines on heavier vans. cheers ivory55
Mar 29, 2011
961
639
Rugby UK
C Class RS
I understood that euro 4 engines were OK for LEZ
Apr 29, 2009
1,204
741
West Sussex
Burstner Nexxo T740
since 2008
We recently uprated our from 3500 to 3700 without any mods. Cost £288 incl vat and was a paper excercise and a visit to the local DVLA Office (they ared mostly being closed so it will soon mean posting stuff to DVLA - not sure how long it will take them to send tax disc back - I am still waiting for the changed V5C after 6 weeks.)
A lot depends on the chassis - dont forget to check your tyres load rating as well - some vans I have seen have tryres on the limit for 3500 so going to 3850 may mean new tyres.
lorger
9,661
90,507
Dumfries
Knaus Sun 650MEG
Also remember it reduces your Tax from £225 - £165 or roughy them figure.
We uprated our new van using vtech no problems what so ever, don't think we will get near the weight but did it just to be on the safe side and will pay for its self in 3 years.
Xabia
1,186
821
Since 1996
The following extract is from the Caravan Club - speed limit signs are NOT required:-
The French highway code stipulates that 80 and 90 stickers must be displayed by vehicles required to drive at the lower limits. The Legal Department of the Automobile Club de France said that UK registered caravans did need to display the stickers, the French Ministry of Transport changed their minds three times: the first reply said no, the second reply said yes and the third and final reply is below:
We have checked with several Government Departments and Ministries (Interior, Gendarmerie, Industry and Transport) and we have concluded that the stickers are not mandatory but the speed limits are applicable.
Mike
43,329
49,444
gross and axle weights explained.
the gross weight is the maximum allowable weight of the vehicle fully loaded and should NEVER be exceeded.
the front and rear axle weights will always add up to more than the gross weight to allow uneven loading.
if your gross weight is 3500kg with the rear axle limit of 2250kg and front axle of 1750kg that means you can load the rear up to 2250kg but you must then reduce the front axle loading to 1250kg making a total of 3500kg...your gross weight
same applies the other way round heavy front, lighter rear.
none of the individual weights should ever be exceeded.
43,329
49,444
Mike
I never knew DVLA had French offices as well. :Doh:
