Burstner Elegance Power Folding Bed Stuck Up (1 Viewer)
JE1
3
5
Cumbria
2years
I have a burstner elegance which has the front power foldin bed stuck in the up position
It just makes a beeping noise when trying to lower it.
Has anyone come across this?
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Jammed ?
Can someone shake it CAREFULLY while the other presses down.
makems
3,440
27,700
Ingleby Barwick,,Teesside
Sadly had to give up
My manual is the van which is in storage so I can't check.
However I have had a similar problem and I think there is combination of buttons you have to hold down for more than 5 seconds.
Sorry I can't be more help but I am suffering from CRS
makems
3,440
27,700
Maybe a stupid question, but the leisure battery isn't flat is it?
Chris
21,054
278,757
None
10 years
What is CRS?
Wombles
10,808
11,132
SW England
Van Conversion
A few years now
From a previous thread - this is what Spidey used to sort her Chausson electric bed:
Enter in programming mode after having switched on the panel. To enter the programming mode, hold the hidden button (between the button UP and DOWN) and the button UP for 7 seconds. The green LED light with the symbol of the key switches on. If it doesn’t, repeat the operation.
Put underneath the bed some supports able to hold the bed in the lowest position.
Press the button UP; the bed descends. Let it rest on the supports and keep pushing until the bed starts raising again. Bring the bed up to its higher position and let it press the electric contact (limit switch).
Let the bed descend and start programming the positions (depending on the model of the bed can be 3 or 4 points). Let the bed descend to the first position, press the hidden button plus the button DOWN. The LED on the arrows will switch off and on again. Repeat with this procedure for the next 2-3 points and the system will automatically quit the programming mode.
Yours may not be the same kind of bed but hope it works for you :)
makems
3,440
27,700
The process I remember was vaguely like this but not as complex.
(Sorry, still suffering from CRS)
J
JE1
3
5
Cumbria
2years
[/QUOT
Bailey58
8,815
29,562
Norfolk and Toftir.
Sold
July 2010 (ex tugger)
That's motorhomefun for you! Amongst the funny comments some sensible answers will invariably creep in. Pay the tenner to join and all the advice, banter, debate, both heated and humorous, and information on a variety of subjects is there for the asking. (y)
jollyrodger
6,282
26,419
Devon/Cornwall
'Obby
Since 1968'ish
I press 1 button eitwelcomed.end of the bed pull it down fall in knackered .
In the morning swing it back up after making it exercise for the day sorted .
Ain't life grand :)
Oh and by the by welcome from Devon
Spend a tenner ...you know you want to .job sorted no silly call center .just silly people salts of the earth (y)
