bulkhead regulator (1 Viewer)
surfbum
30
4
hi top
10 years
Has anyone had problems with buklhead regulators. I have a swirt sundance 590 rs which didnt come with a gas bottle so i went and got one and fitted it. The gas came out very low at the cooker the flame was very poor ,now theres no gas getting thro at all .the swift is new to me,only had it a few weeks ,but its had its hab checks before we got it so assume it is a duff regulator.
Cheers Keith.
surfbum
surfbum
30
4
hi top
10 years
Yes .Even took the bottle back to boc they confermed it was full.
Zigisla
2,581
3,107
Gosport, Hants
Sunlight A72
There is a purge button on the regulator itself, similar to the "Green button" on the crash pigtails. Press this a few times and see if it improves.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
What model regulator is it, have you a picture?
Emmit
8,050
17,793
Pilote Explorateur
Jan.2014
On our 'Vorsprung Tecnik' 'van there is a button to press on the Reg. You have to 'press and hold' for 5-10secs with the gas bottle 'On' for gas to flow.
surfbum
surfbum
30
4
hi top
10 years
On this one there is a tiny yellow button at the top of regulator abd at the bottom is a black plastic cap .neither will press in.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Is the hose clear, if removed can you blow through it?
Zigisla
2,581
3,107
Gosport, Hants
Sunlight A72
Back to basics, the manifold is on but is the regulator switched on?
surfbum
surfbum
30
4
hi top
10 years
Not tried that Techno ,but will give it a go later on today. The motorhome is at my daugters house .
surfbum
surfbum
30
4
hi top
10 years
regulator does not have switch the bottle conector has the screw valve and that is open and manifold is open to cooker but turned off for fridge and boiler.
surfbum
surfbum
30
4
hi top
10 years
Techno ,How can you tell if it has a non return valve in it?. or not.
Zigisla
2,581
3,107
Gosport, Hants
Sunlight A72
Is it different to this one? You can see the yellow switch above the black cap and the yellow buttons.
Techno
Jul 28, 2010
15,475
20,756
May 2010
The valve is in the bottle end of the hose which is the rounded POL connector. If you look up it you will see it.
From memory I think it can be unscrewed and discarded. Just a brass plunger and a spring.
Either way blowing through it will highlight if there is a blockage
surfbum
surfbum
30
4
hi top
10 years
Hi zig Thats the very one .i will go and try the button On my van the the on off valve is round the back so didnt see it like your photo.
surfbum
surfbum
30
4
hi top
10 years
Ill go have a furtle with it and let you know later.cheers.Thanks for the info.
surfbum
surfbum
30
4
hi top
10 years
Right.
Took pipe of and tryed to blow down it ,no joy it seems it is the non return valve . can i remove it or do i need a new pigtail. Cheers Keith.
icantremember
8,341
17,566
Near to Watton in Norfolk
Hymer T-SL668
since 2005
Hi Keith, I'm surprised nobody has already mentioned it, but it sounds like your regulator is "oiled up" ... a well known problem with some Truma regs and will need replacing.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Right.
I'm sure I managed to remove it on the one I had but without seeing it maybe just buy another hose without a valve
DanielFord
3,020
3,086
I have that exact same system, I suspect that the regulator is not the issue.
In the cupboard next to the oven, at the bottom there are gas isolator switches. I suspect you've knocked one of them off. Just reopen the valves and you should be good to go.
[edit to add the tag]
I think you may have missed this post @surfbum
surfbum
surfbum
30
4
hi top
10 years
Yes it sounds like its a new regulator 50 quid ish The yellow button on the side wont push in 'Question is How did it pass its gas inspection from a respectable dealers?.they must have known it was unfit for use.
CHEERS KEITH.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Why does it sound like a new regulator ? You've just said the hose is blocked
The yellow button is the breather for the regulator diapraghm i.e. Not a button at all
surfbum
surfbum
30
4
hi top
10 years
hI dan
I have checked them both under there one for the cooker the other for the fridge both are on thanks'
surfbum
surfbum
30
4
hi top
10 years
Hi Techno
I managed to get the oneway valve out it comes apart with an allen key and a thin bike spanner .just need to go back and try it.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Hi Techno
That sounds familiar (y) well done
