Bulb Warning Light (1 Viewer)
edgy
389
475
bolton lancs
lo line
"I,m a newbie
Replaced bulb on Fiat Ducato 3.0 and now warning light wont go out. Any ideas please
edgy
edgy
389
475
bolton lancs
lo line
"I,m a newbie
Hi it is the bulb warning light and it is amber
DBK
18,029
48,100
Plympton, Devon
PVC, Murvi Morocco
Assuming you have fitted the correct spec bulb and it is working it could be an earth fault or something similar. I can only suggest giving everything a good shake/bang around the light clusters.
Apr 9, 2013
663
373
Ayr
Newbie
With my old Volvo I sometimes found with sidelight bulbs that if the bulb on the other side was equally old but not actually blown (just blackened glass), it could still trip the bulb failure detection system.
Have a look at the the other bulbs.
Tim
TheBig1
17,630
43,324
its a notorious problem that these vans dont like some bulbs. try fitting a quality bulb and see if it resets the bulb failure light. have had exactly the same issue myself
edgy
edgy
389
475
bolton lancs
lo line
"I,m a newbie
Thanks for all the reply,s some good some not . Graham I need to talk to you. do you not realise shirls has got a diploma in H&S and I don't think your comment was that good. Good job she likes you:LOL:
driving
97
100
doncaster southyorkshire
Frankia
hi Ian
have you thought about changing all the bulbs, it could be anyone of them that's faulty, even the number plate bulb can affect it. hope that helps
MikeD
3,936
3,697
London
IH PVC
Since 2012
The vehicle ECU are funny things.
It would have shown a warning light because the bulb failed.
Now you have changed it it probably really wants a PC reset.
But they constantly monitor the vehicle systems. If it sees the bulb fault has been cleared it may well reset it self in a bit.
It might take a couple dozen starts etc but may well sort it self out in time.
driving
97
100
Frankia
Ian
just a thought if its not the bulbs, its the pandemonium pin move it 5% to the right wait 1 minute and move it back, you will find the ECU resets itself to manufacturers specifications. Try that
edgy
edgy
389
475
bolton lancs
lo line
"I,m a newbie
Found it will give it a try(y)
Apr 9, 2013
663
373
Ayr
Newbie
Yes I will definetly give that a go. You fu888ng launatico_O
You haven't said which bulb but if it was a heavily used one (like a sidelight one) the chances are its partner is dodgy.
haganap
12,762
26,457
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
your bulb went out a long time back :LOL:
