brake light problems
Discussion in 'Motorhome Chat' started by nannas-boy, May 17, 2008.
  1. nannas-boy
    nannas-boy Read Only Funster
    May 6, 2008
    58
    4
    All the brake lights on my swift sundance have suddenly all gone out, the bulbs are fine, the fuse is fine. Anyone any ideas as to what my problem is please?
  2. Digger Driver
    Digger Driver Read Only Funster
    Oct 4, 2007
    578
    Lancashire
    Check the switch on the brake pedal!
  3. Tony Santara
    Tony Santara Funster
    Jul 26, 2007
    1,494
    114
    Cheshire (ex Mancunian)
    I guess the next place to look is the actual brake light switch at the pedal make sure that the pedal is making contact
  4. nannas-boy
    May 6, 2008
    58
    4
    fuse problem with brake lights
    Thanks for your replies, but now on closer inspection the fuse has blown, i have put new fuse in and brake lights come on for split second and then blew fuse again, please any ideas what could be my problem?
  5. Tony Santara
    Jul 26, 2007
    1,494
    114
    you've got a short cuircate somewhere on brake light wiring ie a bare wire touching metal or touching another wire
  6. Digger Driver
    Oct 4, 2007
    578
    Lancashire
    Sounds like you have a short in the circuit!
    If your not familiar with a multitester it might be worth the £50 to get an auto electrician to look at it!
  7. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Check the circuit anywhere the wires move / chafe.
    The switch area, as previously suggested, sounds a good area to start.
    I'd remove both the bulbs and check the holders after that.
    You really need a multimeter on the Bulb/switch side of the fuse mounting (with the fuse removed) + lead on fuse terminal and -ve on chassis using resistance reading.
    With bulbs in , Get someone to operate the Brake switch/press the lever down.
    You should see some resistance and not a full short circuit/zero ohms reading.
    Try it with bulbs out.
    With lever pressed you should see open circuit/infinity ohms reading.
    If there's a reading check / move the wiring with the meter still on. If the reading fluctuates, you are in the area of the fault.Then a full visual should , hopefully find the problem.
    This saves blowing loads of fuses and possibly causing damage to the wiring.
  8. toolie
    toolie Deleted User
    or if you wanted to become familiar with a multitester look at these:
    Analogue Multi Tester
    Standard Digital Multimeter
    It's a shameless plug I know ! :Wink:
