Bolero 724FB (1 Viewer)
Trout bum
567
584
Ayr
Adria Matrix M670SL
Started Shuggie up today to take him a wee run get things moving before weekend away , unfortunately EBS and handbrake warning light stayed on , he's running fine despite these warning lights , could it be a faulty sensor somewhere everything else is toot sweet , any ideas ???
Nov 6, 2013
3,201
229,592
East Sussex
Hymer B574DL
Since 2011 (tugger for 20 before that)
How old is it?
On our 2015 Bolero we had the same problem. It was the ignition switch which was replaced under warranty.
DuxDeluxe
14,658
72,784
Planet Zog
A woosh bang van
since 2008
I just knew that someone would be along with a possible solution (y)
Trout bum
Trout bum
567
584
Ayr
Adria Matrix M670SL
Hi John
It's a 2013 model , don't know if it's any help had a wee wheel spin in the mud coming out of the last site we were on warning lights came on then but we stopped on way home for a coffee break and when started up again all were clear , now after it's been sitting for a week on start up they have came back on but van runs okay , was thinking there's maybe dirt on a sensor ?
Nov 6, 2013
3,201
229,592
East Sussex
Hymer B574DL
Hi John
Yes it sounds like it might be related to the wheel spin incident.
Someone more technical than me will be along shortly to advise (y)
Trout bum
Trout bum
567
584
Ayr
Adria Matrix M670SL
The plot thickens with Shuggie started him up this afternoon supposedly to go to Biggar caravan site for the weekend, on start up still have the EDB , ABS, engine management light and handbrake warning light staying on , had a wee drive with it and the temperature display isn't working neither is speedometer but rev counter is , so decide to cancel weekend need to get him booked in to see what's up , so looking forward to a chilling weekend ah well few beers in the house then , hope you guys are having a good weekend
glenn2926
3,326
13,619
Gods country
Chausson
newbie hired 3
We have a car showing the same lights as you also speedo not working. Mechanic sorting it Monday or Tuesday. He says abs sensor is the problem.
Trout bum
Trout bum
567
584
Ayr
Adria Matrix M670SL
Well that's Shuggie booked into Brownhills to get the warning light issues investigated and hopefully sorted , not so happy with there service desk though I have the gold 3 year warranty and first thing they say is , well we will have to see if it's a warranty issue, I can assure you it will be only had it 8 months , pity I need to travel 5 hrs away but can't help it , they haven't said if I've to wait or just leave it , think I can hear an angry Scotsman
Nov 7, 2015
497
469
Newport, Shropshire
Autosleeper Broadway
since 2015 previously caravaning 25 years
It is very likely due to the well known fault on the instrument cluster, often replaced under warranty
Good luck
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
It might be worth having a chat with the Fiat dealer in Galloway Avenue.
Worth a punt, to nip in and speak to the service manager, see if he is familliar with the fault?
Failing that,if you have breakdown cover, have them have a look at it.
Might save you a ten hour round trip.
Trout bum
Trout bum
567
584
Ayr
Adria Matrix M670SL
Hi Bobby
Thanks for the advice , didn't think the fiat dealer in Ayr would look at it as they are more car related , but will give him a ph in the morning see if he's got any ideas , it as you say would save me the long trip , nothing to lose asking thanks again .
Trout bum
Trout bum
567
584
Ayr
Adria Matrix M670SL
Hi Spanner
Thanks for that , didn't know there was an issue with the dash unit , Sod's law I have an older van for 7 years no sensors or modern technologie , ran great swop for a more modern van and problems too much electronics and sensors on them these days I think
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
Hi Bobby
The AC fiat dealer in Paisley serviced my last ducato at their garage. They should be able to plug it in and fault find, if it is a recall job they will love it.
Trout bum
Trout bum
567
584
Ayr
Adria Matrix M670SL
You wouldn't have an address or number Bobby I could ask the question
Trout bum
Trout bum
567
584
Ayr
Adria Matrix M670SL
Update on warning light issues , engineer at Brownhills have found
The EBS control unit is u/s but because it's a costly part an assessor from fiat need to check it out, Elle on service desk has been amazing organising the assessor to attend the same day to check it out , part is authorised and hopefully will be sent o/night to be fitted Friday, and head back up the road , drive down was an experience because engine management light was on did not have full engine power , but got here eventually , staff at Brownhills have been very good indeed , hope the part arrives ok
Gellyneck
9,235
18,211
Scotland
More than toes wet now!
Hope everything gets fixed OK for you.
For future reference I've found Imperial Commercials (off Shieldhall Road in Glasgow) good for Fiat base vehicle repairs. They've done the instrument dash cluster (as referred to above) twice under warranty.
Trout bum
Trout bum
567
584
Ayr
Adria Matrix M670SL
The plot thickens with Shuggie they have fitted the ABS control unit but still getting an error code coming up so they are going to fit a hub unit and if that doesn't cure it a new sensor , but don't have any in stock and will be Tuesday before they can acquire one , so if it is the sensor service girl is going to see a senior manager if they can take one off another motorhome , 3 day we have been here , keep saying they work on motorhome first thing in the morning , but nearly 10 am and it's still in the overnight parking lot , will we ever get back home ?????? ☹️☹️
Trout bum
Trout bum
567
584
Ayr
Adria Matrix M670SL
Update on warranty work new ABS CONTROL UNIT , two hubs , 2 speed sensors , still fault came up mechanic then found a wire running along the chassis to be bare and shorting out on chassis , run new wire started Moho up and all warning lights are out yippee , left at 4.30 back in Ayr 10 pm run like a sweetie cruise control nearly all the way thankfully all sorted now , get him washed up and polished next weekend then away the following one for a couple of days , back to normal thankfully, couldn't help but notice though that an awful lot of Autotrail mohos in for repair at Brownhills and all nearly new ones .
musson
487
165
grantham
low profile
since Jan 2014
If its the dash panel call fiat before you take it to brownhills I did and got fiat to ring brownhills to sort the problem
Gold three year warranty have to say I have had three vans from Brownhills and so fare apart from complaing about the service desk staff only one I have had no issues
Trout bum
Trout bum
567
584
Ayr
Adria Matrix M670SL
Hi Musson
They found eventually a bare wire along the chassis running from the rear speed hub to the engine compartment , all well now no issues with the technical staff but service desk are very slow to react sometimes ,
Good to get Shuggie back to normal now .
