Blown a fuse!! (1 Viewer)
Oct 5, 2012
25
79
Taunton, UK
Looking for A class
Evening all. This is my first post having wandered on the periphery of the site for a few weeks now....please bear with my ignorance. I've bought a 2005 Bessacarr e745 last week and I'm getting the hang of it.....well thought I was.
All was going relatively well until this afternoon when I bought a Dyson fan thinking that it would be very useful (and cool!) in saving my gas while on hookup here in Ireland. Bad idea. I plugged it in to the socket in the overhead locker for the tv, it started, went for about 5 seconds and then stopped. Now I have no 240v. None of the trip switches in the Electronic Control System (Sargent PSU 2007) were tripped but now neither the Charger or Heater Lights are on.
I've checked the fuses in the leisure batteries and they're all fine. I've also checked the power from the house and that is fine too.
Any help would be greatly appreciated.
icantremember
8,333
17,545
Near to Watton in Norfolk
Hymer T-SL668
since 2005
Hi and welcome to the Fun
It sounds like the ELH has tripped out at the site outlet ..... try plugging into another hook-up point
If this is the problem then you may be able to reset it yourself or you may have to get site staff to sort it
444
49
surrey
hymer A class
since 2010
just a wild guess, is there a fuse in the hook up cable,
good luck
WildeCamping
Oct 5, 2012
25
79
Taunton, UK
Looking for A class
Wow!.....that was fast! Many thanks for that. However, I'm plugged in on hookup at home and the socket inside that I am using hasn't tripped and can charge other things (i.e. my phone charger). The problem seems to be within the 'van....
icantremember
8,333
17,545
Hymer T-SL668
since 2005
If you have a normal 3pin plug on your hook-up cable the fuse may have blown, particularly if you were running any other electric items when you put the fan heater on.
5,545
18,775
Mobilvetta Euroyacht
1996, then break 'til 2011
Might sound obvious but have you pushed the hook up plug right into the socket on the van? try unplugging and plug it back in ............
:Smile:
WildeCamping
Oct 5, 2012
25
79
Taunton, UK
Looking for A class
Panic averted!
Ahhh......it was the fuse in the plug. Have changed it and now working fine again.....no more bling bling for me in the 'van I guess. Will stick to woolie jumpers etc. to save the gas!!
Many thanks for all your help. It is much appreciated.
Ultan:thumb:
oldun
747
162
St Neots
VW Campervan
Since 2001
Ultan:thumb:
Many motorhomes have the sockets fused internally at 10 amps with the lights etc at 5 amps.
This means that the sockets are limited to about 2.3 kW bearing in mind that you may well have the fridge and battery charger running off the same circuit you may have around 2 kW for everything else. This will be true even if you have a site supply of 16 amps.
Why not get motorhome friendly electric kettles, heaters etc that run at 1 or 2 kW?
Check the fuse rating of your mains distribution unit and always check what else is running before adding further units to the mains supply.
Stonemags76
1,280
3,995
Derbyshire Dales
Auto Sleepers Warwick Duo
Full Time 2011-2013, now part timers!
We have a bessecar E630, and ran a dyson fan all last summer in France with no problem. Obviously we didn't put the electric hob or the microwave on at the same time, but had no problem with the van electric on hook up.
It may be that the three pin plug from your house just wasn't strong enough?
Try it on a site before you give up because those fans are brilliant - we can have it on the floor for our old dog, and he can't hurt himself because there are no blades.:Smile::Smile::Smile:::bigsmile:
WildeCamping
Oct 5, 2012
25
79
Taunton, UK
Looking for A class
::bigsmile: You're right re: Dyson. Once I realised that it was the fuse in the plug rather than the heater I went back to the shop and bought (back) the fan!. Now it's running in the background as I write this with my two dogs sleeping on the seat next to same (-1 deg here tonight!). :thumb:
canopus
6,139
10,260
rural Lincolnshire
Carado CV640 Pro
Since 2010
Many people use retractbale extension cables which are often inadequate for loads of more than 10 amps.
Rule of thumb - if the appliance is used for heating ensure any plug top fuses are 13 amp. Ensure any extension cable size is rated for the load of the appliance, is fully pulled out and not left part coiled on reels or cable tidys. :thumb:
WynandJean
6,670
3,303
West Midlands
Bailey Autograph 682
Since 2010
I know it's not directly related but thought I'd mention that I've replaced all the fuses in the 'moho' with LED fuses. If the fuse blows it lights up an inbuilt LED so no more checking fuse after fuse. :thumb:
Wyn
oldun
747
162
St Neots
VW Campervan
Since 2001
Nobody seems to know where all the fuses are placed in any given motorhome and that includes the manufactuers.
Toilets etc often have fuses placed locally, tucked away out of site in some inaccessible place.
Often you have to rely on other owners fuinduing them for you.
My Devon monaco had a distribution unit containing a fuse marked frisge. Did this control the fridge- no! The frisge fuse was located close to the leisure battery, along with several others.
Best of luck.
johnp10
7,774
15,181
North Lincolnshire
8 years ish
HI,
I have a 2000 e 745.
Is the offending circuit mains 240v, or did you plug into a 12v tv socket?
If it's 12v, there is a spade fuse for the overhead lights etc. tucked away.
