Been given TWO 15Kg FULL Butane Bottles (1 Viewer)
Mar 12, 2012
1,395
1,612
Bridgend, South Wales
Just started!
I know the fittings are different between the Butane & Propane bottles - is the regulator different?
There's an adapter to take care of the differing connectors but at £28, probably not worth the bother!
Feb 16, 2013
19,735
52,035
uttoxeter
ambulance conversion
50 years
We have a fixed regulater in our van and we use propane but in the book it says we can use either so presumably the reg works with either, although Butane isn't as hot as propane it must be worth a shot as one bottle is more than your adapter but they must be pretty common have a look at boot sales or eBay
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
"Yes".......... as far as I`m aware...
Blue Reg for butane and red for Propane...
I believe the preasure is different...
I stand to be corrected... :winky:
voyagerstan
324
214
torquay sometimes
library bus (ford voyager
since1976
yes presure is diferent but nothing to wory about one just burns hotter and £35 afilli would go for it .:Smile: stan
regulater on amazon £8.99
StitchUp
Mar 12, 2012
1,395
1,612
Just started!
That's good to know :Smile:
All I need is a the tube from the Butane cylinder to the regulator. I'll see what I can find online.
Heyupluv
3,862
1,593
France,
touring many years..42+
Here you are also these tails ill fit the French Propane bottle..... :thumb: Link Removed
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
hi. you need a clip on to w20 adaptor . not a reg . then remove the camping gas adaptor from that other brass piece . .that is an adaptot for w20 to uk pol .
using the bas catalogue you need part no. 16642 21mm clip on adaptor .
you have part no.21123 that changes the old uk butane to uk propane thread .then your pigtail you have will fit .keep the camping gas adaptor if you are really pushed you could use a camping gas bottle .
if its complicated pm me and i,ll give you my tel number . i think that was a lucky gift.
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
heyuplad he doesnt need that he as the fitting there to adapt butane to his propane tail . its on the camping gas adaptor .
