Battery (1 Viewer)
catjo2002
4
Essex
Talbot Swift Capri 1990
New to it all!!
Ok - this is how clueless i am - i think i have located the leisure battery under the passenger seat - does this just automatically charge itself if i use the hook up? And how does the van know whether to run off the hook up or the leisure battery? ::bigsmile:
43,331
49,467
yes that will be the leisure battery.
have a look at your control panel....the one with the gauges on, possibly near/above the door....and there may be a 3 position rocker switch with a cab (engine end) symbol, a van (living end) symbol and possible an off position in the center.
when on hookup, put the switch in the van position to charge the leisure battery, or in the cab position to charge the engine battery.
in the center position neither battery is getting charged but all your 12v stuff will work on the charger alone.
when off hookup you should have the switch in the van position or you will flatten the engine battery
your charger actually doubles up as a power supply for all 12v equipment when on hookup with your battery acting as a reserve supply if you use more power than the charger can supply.
hope this helps in some way.
DuxDeluxe
14,658
72,784
Planet Zog
A woosh bang van
since 2008
Thanks - I wish that I had known that with my previous van, which had exactly that sort of control and I could never figure out what it actually did (Lunar's instructions are notoriously useless). The new A/S van instructions actually explains the digital control panel in some detail and very clearly
normanandsue
1,871
21,571
Dunfermline - Scotland
van conversion
Amazing how simple and basic questions cause you to think. Having an older van 1998 Autosleeper I don't have such a fancy control panel. I do have a master rocker switch as you say John but it is only two way on/off. I have assumed when on ehu the leisure battery and the van battery automatically charge without me having to do anything.
As I have had no problem with my electric supply I have never given this a thought, but now reading this I wonder if my assumption is correct?
Norman
C
catjo2002
4
Essex
New to it all!!
Pappajohn, thanks for the advice.
Will give it a go, I am very new to this and daresay this will be the first of many daft questions
Thanks again.
Jo:thumb:
43,331
49,467
Norman
i doubt both batteries will be charged at the same time but the 2 way switch may be leisure one way and cab the other :thumb:
