Battery Monitoring.. (1 Viewer)
Zigisla
2,580
3,106
Gosport, Hants
Sunlight A72
If you have a battery status monitor in your unit that tells you the charge state of your battery, how does this work if you have two batteries. Do you read the total charge of both? If so, is there any real way of telling if one battery is draining faster than the other?
Sep 22, 2013
200
199
Halifax
Relay self-build
Trainee MH owner
No there is no simple way to do this just using a standard battery monitor if the two (or more) batteries are correctly connected together to work as a single large battery. The options for investigating their separate performance would be:
  1. Disconnect and test separately (if you have the skills and equipment to do so)
  2. Depending on your battery type, it might also be possible to use a hydrometer to check the specific gravity of individual battery cells and see if there are significant variations that indicate one or more cells are faulty
Don Quixote
2,966
5,258
Lost in La Mancha, Spain
VW T6 Campervan
I fitted the Victon 600s and it tells me everything I nee to know about my batteries.
2,345
10,186
A basic analogue system on the Hymer..
A Galvanometer that shows direction of current .. in amps
A Voltmeter that shows state of charge .. in volts
everything I need to know
