Battery Monitoring..
Discussion in 'Tech/Mech General' started by Zigisla, Nov 7, 2015.
  1. Zigisla
    Zigisla Funster
    Oct 24, 2015
    1,182
    1,334
    Fareham, Hants
    If you have a battery status monitor in your unit that tells you the charge state of your battery, how does this work if you have two batteries. Do you read the total charge of both? If so, is there any real way of telling if one battery is draining faster than the other?
  2. hilldweller
    Dec 5, 2008
    27,505
    26,587
    Macclesfield
    NASA BM1.
    But it would treat any number of batteries as one big one.
  3. ericroy
    ericroy Funster
    Sep 22, 2013
    103
    77
    Staffordshire
    No there is no simple way to do this just using a standard battery monitor if the two (or more) batteries are correctly connected together to work as a single large battery. The options for investigating their separate performance would be:
    1. Disconnect and test separately (if you have the skills and equipment to do so)
    2. Depending on your battery type, it might also be possible to use a hydrometer to check the specific gravity of individual battery cells and see if there are significant variations that indicate one or more cells are faulty
  4. Don Quixote
    Don Quixote Funster
    Jul 29, 2012
    2,506
    3,720
    Lost in La Mancha, Spain
    I fitted the Victon 600s and it tells me everything I nee to know about my batteries.
  5. scotjimland
    Jul 25, 2007
    28,935
    25,624
    A basic analogue system on the Hymer..
    A Galvanometer that shows direction of current .. in amps
    A Voltmeter that shows state of charge .. in volts
    everything I need to know
