Battery condition - guidance please chaps (1 Viewer)
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
I think I know the answer to this but would appreciate a second opinion from one (or more) in the know.
I have 2 x 110Ah Elecsol batteries - they are over 6 years old. Most of our time is spent off-grid but we have a 135W solar panel that keeps them topped up very well between April and October.
Last September, the system shut down on us unexpectedly in France when I thought the batteries would still have had a decent level of charge. That was after about 4 weeks without hook-up. Following 2 days on hook-up we carried on for another 2 weeks without problem, relying only on the solar panel and alternator when driving.
I have just been doing some rewiring and took the opportunity to disconnect the batteries and test them. They were previously fully charged but had rested for 48 hours without any load before I proceeded with a test.
Here comes the question. After about 6 hours discharging one battery using a 21W bulb, it appeared to recover charge OK after resting, to around 12.5 volts. I then proceeded to do the same test with the second battery. This time, before disconnecting the lamp after 6 hours, I tested the voltage across the terminals whilst it was under load - 9.2 volts! At that level, the EBL would have shut down the system (as it did in France). I think it is time for two new batteries - Agreed?
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
in September the solar is not working at its best due to the low angle of the sun. However your test shows a marked discrepancy between the two batteries and at 6 years old they have done well.
So yes time for some new ones, try battery megastore at tewkesbury.
43,331
49,470
Less than 2 amps would not drag the on-load voltage to 9.2v.
A fully charged starter battery may show that voltage while starting the engine....400amps load or more.
6 years from elecsols must be the exception...certainly not the norm, which could be why they stopped trading.
evidently nothing but trouble and a three year warrenty not worth the paper it was written on
JeanLuc
JeanLuc
3,304
2,199
Warwickshire
Thanks all - you have confirmed my thoughts and I'll get a couple of new ones.
Not sure about the Banners Jim although I accept that they are good batteries, they are not sealed and this is an internal installation. I do have vent tubes already though.
I have been thinking of getting Varta 'professional leisure' which are sealed and use calcium technology. They also make the low profile that the Hymer requires model LFD90
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Mine came with 7 yr warranty but I didn't buy or choose them myself.
Jim
Ringleader
Jul 19, 2007
36,429
130,937
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Not sure either, I've been told they don't need venting but don't know how true that is. I think @Techno100 prefers another brand of battery, but can't remember the make.
Techno
Jul 28, 2010
15,475
20,756
May 2010
A number of brand names cover the same battery Jim
from Alphaline to Numax but it is a DC31 125ah 4 yr warranty at around £85 delivered.
Banner are not sealed and require topping up if overcharged. Sealed batteries have labyrinths to keep the electrolyte from leaving the confines of the unit.
Typical example
The battery terminal connections offer superb flexibility for adding extras
Reactions: ebo
D
deleted-member02
Fwiw I fitted a Varta LFD180 and am delighted with it.
Previously had an Elecsol 220ah (from Vanbitz) and a sealed calcium 225ah Xplorer (from Alpha Batteries)
This one, supplied by Eurobatt, holds a good charge, I get a good 24hrs longer than before, even in cold temperatures.
This despite it being 40ah smaller on paper...
Not a scientific study, just my observation (y)
Feb 24, 2013
13,083
101,454
Bolsover, Derbyshire
Hymer S800
not long enough
although you have had a good life out of your batteries, this does highlight a potential issue of multiple batteries
when we bought our used MH I couldn't make sensor of the 12V side of things, (mainly my lack of knowledge and understanding) but massively aggravated by one of the two batteries fitted having failed
On charge all seems well, off charge nothing worked
I opted to replace both, but then found out one was completely gone the other was still very good and has gone on to give 2 more years good service for a friend in need, but the one failed battery completely skewed the voltage from the pair, dropping the combined voltage well below 10V despite one having nearly 13V
I am sure you are well aware of this Philip, just adding this to a thread to possibly assist other low tech MHers like me
JeanLuc
JeanLuc
3,304
2,199
Warwickshire
Thanks for all the observations and suggestions everyone. I know Techno has had good experience with the Alphaline and I have not discounted it. But having spoken to the Varta technical people and done a bit of research, I'm tending towards 2 x LFD90 (professional dual-purpose). I think for all practical purposes, Varta's 2x90 Ah may be the same as Elecsol's 2x110 Ah; I seem to remember that there was some controversy over the way Elecsol quoted their capacities (not using the 20 hour standard).
I am limited to the size / format of the original equipment Exide 80Ah gels 353 x 175 x 190 high and that is the same as the Varta LFD90.
In case it is of interest to anyone, I specifically discussed with Varta, the matter of using the their Silver Dynamic (same as Bosch Silverline) as recommended by A&N Caravan Services. These are starter batteries that are designed to recharge very quickly. A&N state on their website that they are better for motorhome use than a standard leisure battery. Varta said that whilst they were delighted to have their batteries promoted, they would not recommend the Silver Dynamic for leisure use and that they were the people who had to honour their product warranty.
11,953
16,570
I've recently replaced my failing 3 year old Elecsols with Banners. They are sealed other than the need for the single vent tube (ie individual cell caps are sealed). Mine are under the drivers seat & are vented via the vent tubes.
JockandRita
11,462
150,163
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Not really John. Philip is in good company, as ours lasted just over seven years. (y)
I was very pleased with our Elecsols, and had one in a caravan for some years before.
With good advice and help on here from Jon (@jonandshell ) we, and Forestboy are on Trojan traction batteries on our Hymers. They are great batteries, but do need monitoring for electrolyte levels ocassionally, so no good for installation under "difficult to remove" seats.
@Jean-luc , Philip, I am pleased to read Varta's response to the A&N article re the Silver technology batteries. Good luck with your replacements. (y)
Cheers,
Jock.
ebo
Nov 9, 2009
98
105
A class Carado i449
Typical example
Anyone know if the Sargent PSU2007 would cope with charging two 125ah together? Is there any issues around the more batteries you have? Andy's link to the Hankook seems a great deal.
jonandshell
5,476
8,299
Not got one!
Apart from never completely charging them, no problems at all!
Sargent don't really make a great split charge system, their cables are too thin and the resultant voltage drop ensures only minimal charging current with the engine running.
EHU charging would be fine though.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Should not be a problem but a phone call to Sargent will put your mind at ease. Technical dept 01482 678981
Reactions: ebo
WAG2CRU
376
495
Argyll
Hymer B654SL Star Edition
since2012
I am no expert on batteries but after many years of sorting out charging systems and batteries on sailing boats, which is a challenging environment for batteries, I found Merlin Power Pack multi purpose batteries to give excellent performance particularly the 113ah 31T which is a Trojan battery and seems ideal for motorhomes. Have a look at power-store.com.
ebo
Nov 9, 2009
98
105
A class Carado i449
Thanks jonandshell & Techno100 emailed Sargent came back with fast reply 'wont be a problem'
