Awning leak (in between van & device) (1 Viewer)
Ridgeway
3,657
6,152
Lausanne
NiBi Arto 85E
Since 2012
Firstly we are lucky that we don't get that much rain between March and October when we are camping and so this has only happened twice so far. Basically when it rains quite heavily and perhaps if the van is parked a certain way (not sure) the the water will run between the Omnistore body and the MH side, only in 1 or 2 places and even that is hard to tell. As the water then drips off the Omnistore it falls onto the window edge and splashes all over the place = wet chairs, tables etc.
As you guys are more used to dealing with the wet stuff any suggestions on a solution ?
I'm sure once I saw a special seal for the top of these awning units or is it ok just to get the Sika on it ?
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
duane0001
792
778
East Coast, North Yorks
Expedition 67 soon!
2021 This time
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
Why can you not post abroad?
Website cannot compute cost of postage for parcels as Post Office charge not only by weight but volumetric size as well, very complicated and all our postal items are collected from us by Post Office van.
Courier costs for shipping abroad are also very expensive.
Peter
Minxy
32,651
66,544
E Yorks
Carthago Compactline
I'd just use a bead of sealant along the gap as it sounds like that should do the trick. :Smile:
jollyrodger
6,282
26,419
Devon/Cornwall
'Obby
Since 1968'ish
Omnistor awning seal as Peter says common accessory
you can try Thule (who bought out omnistor I think ) Belgium
http://www.thule.com/en/gb/products...stor-5003-_-thule-omnistor-5003-white?ls=true
the part you need is in their catalouge and there for download
docs.thulegroup.com/Thule/outdoor/RV/thule rvcatalogue2013_en_gb/
not sure of fit to your particular van ,but there is an runner channel on top/back of awning case rubber seal slides into this and spans onto van to form seal .Possibly solve your problem ,and an easy fit job
Ridgeway
Ridgeway
3,657
6,152
Lausanne
NiBi Arto 85E
Since 2012
Thanks guys.
Just back from another rainy day so will ave a look at this tomorrow.
The unit looks very close to the MH body so hoping that sealant will be enough but will look at these dedicated seals
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
Mine has quite a gap, but doesn't bother me as I only normally use it as a sunshade. The sealant might not be enough on it's own however you should be able to buy the official sealing strip from any motorhome/caravan place anywhere in Europe. Theses things aren't made in the UK anyway.
Ridgeway
Ridgeway
3,657
6,152
Lausanne
NiBi Arto 85E
Since 2012
Ok had a look today and the conclusion is that the muppets that fitted the awning (largest MH supplier in Suisse) used a cheapo grade of sealant for the 7-8mm gap between the awning body and the van. In short the sealant has shrunk in places and there's an odd small gap, this just proves that its worth using good materials for these simple jobs (will remind the supplier...)
After some scraping and cleaning and some newly squeezed Sika, it looks good to go:Smile:
