Awning C rail diameter ... (1 Viewer)
Scotties
439
318
Norfolk
Hymer
Since 2006
Several of you on another thread have said you've fitted the normal C rail instead of using the track in the awning. I believe this is a 7.5 mm channel and the awning channels are 5 mm. Apart from the ease of threading are you guys happy about the normal Kampa type strip not pulling out of the rail.
Also have any of you tried using the drive away kits with the Kampa air type awnings.
Many thanks for any input in advance.
scotjimland
2,334
10,102
A Woosh bang
The Kampa Rally Air Pro has a double bead.. 4 mm for a pullout Awning and 6mm for a rail
I fitted a rail a couple of weeks ago... http://www.motorhomefun.co.uk/forum/threads/awning-rail-fitted-for-kampa-rally-air-pro.135228/
and it was blowing hard when we were at Wales.. no problems with it pulling out
NOTE: It actually pulls over more to the right to completely clear the fridge vent
Scotties
Scotties
439
318
Norfolk
Hymer
Since 2006
Many thanks Jim, I'll get out there with the drill and fit it.(y)
Jan 10, 2013
5,958
7,354
Near Uttoxeter and Crete
Warwick XL PVC
Still trucking and learning
We're thinking of doing the same thing - can you report back to let us know if it's as easy as @scotjimland says - don't forget we're numpties and Mark is left handed and doesn't have a full complement of digits!
