Avtex Snipe or Snipe Pro?? (4 Viewers)
RowleyBirkinQC
2,348
227,203
Dazed & Confused
I'm contemplating a Snipe (or similar system) for free to air satellite channels across UK and maybe near continent, not overly bothered about reception in South of France onwards etc. With this in mind, I would really appreciate your input on the following...
I appreciate the Avtex Snipe Pro Max is an updated system with claimed performance of a larger traditional dish than the standard Snipe or Snipe Pro. However, for roof mounting purposes, given the price differential, is there any real benefit in the Snipe Pro over the standard Snipe?
Are there any alternative systems of a similar type/price I should also consider? I quite like the idea of smaller/flatter system to a dome.
Thanks in advance for any pointers! :)
wingman
1,217
3,333
Romford, Essex
Coachbuilt Lo-Profile
Hi RowleyB QC
I've recently bought the standard Snipe. Very pleased with it so far around the UK, but won't get a chance to try it in France until I go over there in the summer. Folk give the standard model good reports abroad though.
I considered the Pro model, but the price hike was quite significant for very little gain. It seemed that you were paying a lot more, just to have a double input for a recorder.
I also decided not to permanently roof-mount mine. Didn't want to drill yet more holes in the roof and anyway, I wasn't competent enough. I was bound to hit some strut or underlying hidden feature!! I just pop the Snipe through a large Hekki rooflight and plant it on the roof. Bit of a palaver, but at least I don't have holes, or the wind resistance and drag. The other reason that I didn't fit it, was if I changed the van, it would have to go with it and I'd need to buy another Snipe.
I'm not a great lover of domes, although there's those that swear by them. They too, are pricey and add to the height measurements for tolls and ferries.
Haven't had any comparison to help you with, because I only had a bog-standard tripod exterior dish before and spent ages shouting through a window to the wife to see if we had a picture :mad: The Snipe roof profile is probably as low as most other dishes and unless you have an absolute massive dish, the Snipe horn array compares quite well, signal wise.
However, there are better experts than me! I found @lennyhb most helpful.
James
53,495
150,307
I have the standard Snipe very pleased with the performance locks onto Astra 2 a long way south in France the reception ares doesn't appear much worse that the Oyster 85 on the last van.
The only advantage I can see with the Pro it can be wired to fold down with the ignition turned on, as the standard snipe goes down if you turn the power off & on you could wire in a timer relay to turn the power off for a few seconds to achieve a similar result.
Builder147
77
69
Devon
C Class bessy E560
Getting the hang of it
We have the snipe pro and very pleased as well, it is wired into the ignition so if you do forget to put it down it auto goes down when the ignition is switched on. Have only tried it in the UK so far but no troubles at all. We had ours fitted by "outdoor bits" in Exmouth as with a 140w solar panel and 2 new banner 110amh batteries, they made a good job of it all,very pleased.
Landyguy
200
86
Sutton on Sea
Autotrail Serrano
newbie from caravan - 5yrs now
Landyguy
200
86
Sutton on Sea
Autotrail Serrano
Could you let me know much all that work cost as I am considering some if not all of that equipment upgrade.
leeboy
136
61
Sheffield
newbie
Just installed snipe to our Chausson, Love it!
Lee.
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
We have the snipe, the pro didn't exist when we got ours.
The main advantage in the pro is the extra arms for better stability in wind etc.
Think I would have paid the extra given the chance.
scotty1
254
38
Kent
Wildax solaris xl
Snipe or pro? Fitted or not fitted(storing in motorhome) when i look at photos one is square the other oblong,what are the sizes in box?????? Many thanks Scotty
Mar 21, 2009
1,368
875
Harwich, Essex
4 years
I fitted a Snipe (not pro)to roof of my MH this week, put in Sky box this morning to try and every thing works fine. Switched off power to snipe and held its position even though its blowing a gale.
Did want to use it as a portable unit as we might change MH in future but its quite a chunky and heavy unit to lug around, so as it came with base plate easy enough to mount on roof.
RowleyBirkinQC
RowleyBirkinQC
2,348
227,203
Dazed & Confused
I believe the Snipe and Snipe Pro both use the same size receiver panel (the Pro is designed to be a roof mounted system apparently), the Snipe Pro Max has the larger receiver panel.
scotty1
254
38
Kent
Wildax solaris xl
Hi jaygee,did yours come with plate? If so where from and at what cost. Did it come with case ifso do you know the size of it inc case for finding somewhere to put if i dont fit cheers Scotty
Mar 21, 2009
1,368
875
Harwich, Essex
4 years
bought it off ebay from here
seller = Broken Link Removed
I made offer & got it for £570 incl delivery. It came quickly and good communications ( I thought they hadn't sent the base plate so contacted him to complain, he phoned straight back & asked me to check it wasn't in the box - lo & behold it was tucked between two pieces of cardboard!! very embarrassed)
It was the only one we found that came with the base plate.
Can't give you measurements as the case is in the storeroom at work - they should be on the site somewhere?
Tony put it up on the motorhome roof in the week and has just been out there today and set it up using our sky box (we have ordered a 12v box but not yet here) he was only out there a few mins and came in & said it was all up & running & was really easy to do - for him (a technophobe!!!) to be able to do it it must be easy - he can't usually even turn the computer on without creating a problem :Eeek: and there is usually a lot of :swear2::swear2::swear2::swear2: when he's doing anything technical:)
Jacky
scotty1
254
38
Kent
Wildax solaris xl
RBQC if he had a fixing plate in the box you must be able to fix the standard one on the roof?
RowleyBirkinQC
RowleyBirkinQC
2,348
227,203
Dazed & Confused
The original Snipe promotional video includes reference to roof mounting in addition to it being a portable unit. I can only assume the Pro was then released to improve on the original specifically for the purpose of roof mounting - I think it is only the base which has changed to become circular, with addition of strengthened arm/strut to better support the panel. However, the Pro is a hell of an uplift in price for that modification over the original version.
But I am no expert here...
RowleyBirkinQC
RowleyBirkinQC
2,348
227,203
Dazed & Confused
Well let's hope so, as I've just purchased one from the same eBay site as jaygee! :)
They are still taking reasonable offers...
Thanks for the tip Jaygee!
RowleyBirkinQC
RowleyBirkinQC
2,348
227,203
Dazed & Confused
This is the Snipe promotional video for the original unit which explicitly shows roof mounting:
Also, Webbs are an official "Avtex Snipe Installer" and continue to sell the original unit and roof mount such.
1,368
875
Harwich, Essex
4 years
case measures 240 x 530 x 600
scotty1
254
38
Kent
Wildax solaris xl
Many thanks going to search and see what best deal i can get fitted? Ta
RowleyBirkinQC
RowleyBirkinQC
2,348
227,203
Dazed & Confused
SWMBO has just called to let me know the Snipe has now arrived at home, complete with the additional vehicle mounting base plate!! :)
scotty1
254
38
Kent
Wildax solaris xl
If i buy the same as RBQC does any body know where i can get it fixed by approved fitter( warranty) in Kent? Ta
RowleyBirkinQC
RowleyBirkinQC
2,348
227,203
Dazed & Confused
Have you tried the dealer locator on Avtex website, they list "authorised Avtex snipe installers".
However, I called my local "authorised installer", and they gave me the number of the independent AV guy who they use for such jobs, so go figure...
scotty1
254
38
Kent
Wildax solaris xl
RBQC are you fitting yours or have you had estimate for fitting? Ta
RowleyBirkinQC
RowleyBirkinQC
2,348
227,203
Dazed & Confused
I don't trust myself not to bugger it up, so I'll not be doing it. The AV guy estimated 2 to 3 hours to fit at £40 per hour.
