Autotrail Mohican - habitation door won't shut (2 Viewers)
KeithQ
Scunthorpe
Hi,
Just wondering if anyone has had a similar problem. The fly screen on the habitation door seems to be preventing the main door from closing properly, the hinges are bending and it is moving out of position.
Any ideas?
R
Robert Clark
The fly screen should be fully retracted to enable the habitation door to close
If it won't retract fully - check that the frame of the fly screen is sitting properly in the runners and is not catching on something
Reactions: f6c
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
If it is not of the sliding type check the hinges they are often seized and then bend when opening and closing the screen altering its position within the door frame
Geo
MikeD
3,936
3,697
London
IH PVC
On my Autotrail tracker the bottom fly screen runner often fills with stones/grit and does not fully retract but it has never started to bend the hinges.
K
KeithQ
Scunthorpe
It isn't the sliding type, it is hinged. The hinges are bending and altering the position of the screen but do not appear to have seized but the metal doesn't seem to have any strength. I am thinking of cutting off the screen as I can't think of any alternative.
sdc77
3,244
4,550
Weardale, Co Durham
We had a problem with the hinges on our Chausson that resulted in them having to be replaced. Nightmare job sourcing the hinges and navigating Triganos new parts system.
Ours were divided in two and the flyscreen part had started to seize. We removed the flyscreen from the hinges while we waited for the hinges to be sourced
