Autotrail control panel probs (1 Viewer)
beachcaster
3,044
3,161
east sussex
a few years
Just been away for a few days........the Sargeant control panel on my Autotrail Cheyenne is working fine apart from showing correct water levels in the cold tank and in the waste tank.
It is showing 0% full........even though I know its at least 40% full.
Then it is bleeping to show the water is low. So I have to turn the pump off to stop the bleeping.
I read a tip on line to say dissconnect the panel then reconnect but Im still getting the same.
From a practical point of view all is working well..taps etc. But Im one of those people who likes everything to work as it should.
Any thoughts please ??
barry:Smile:
Scout
3,959
121,329
South Yorkshire
chic c line
12 years motorhoming, a lifetime of living
barry:Smile:
mine never worked when I got M/h, autotrail put new cable in , it worked ok for a while, it dosnt now, if its the pannel do the disconct thing a few times leaving the pannel of for a good 5 mins, sometimes the sensor pins on the inside of the tank get crud sticking accross them and can cause false readings so clean out you tanks, allthough this is less likey on the fresh tank, worse case find the wire going to pins on the tank and disconect them, at lest the allfull beeping will stop.
Mines the otherway arround waist allway show empty and Im allways flooding my pitch:Doh::Doh::Doh:
Feb 9, 2008
8,951
18,708
Corby, Northants
Coach Built
I've had the same problem and although covered by warranty the fault has returned after replacing the tank sensors.
My temperature reading is also fluctuating and the latest diagnosis I have been given is an earth fault in the Sargent control panel which will be replaced (under warranty).
My alarms were also triggered but all I had to do was press the control panel select button to cancel out.
Scout
3,959
121,329
South Yorkshire
chic c line
the temperature sensor comes out under the floor near the hab door, again crud can damage this from road muck being thrown back from the front wheels.....
