Arm rest (La Strada) (1 Viewer)
MattR
4,104
38,878
Beds
Panel van
Years
The arm rest on our La Strada PVC needs some attention as the foam inside the cover has shifted about so I need to take the arm rest off to stick the foam into place. I've undone the zip and removed the obvious bolt but the rest remains in place. There is a large hex bolt on the underside of the arm - I assume that is the thing holding the arm rest in place. If I undo this hex, will it cause any problems? The arm rest has roller dials on the underside that adjust their height.
MattR
MattR
4,104
38,878
Beds
Panel van
Years
Repair made today using 13mm socket, 8mm Allen / hex and gaffer tape. All went back together again :)
Nov 6, 2013
3,201
229,477
East Sussex
Hymer B574DL
Since 2011 (tugger for 20 before that)
Sorry you didn't get an answer @Mattyjwr
Obviously those that know didn't see your post.
Glad you sorted it though (y)
