scotjimland
- Jul 25, 2007
- 2,334
- 10,102
- A Woosh bang
I quote from an RV writer
Well, having owned an RV for almost four years and lived in it full time for over two, I feel I can make an honest and fair assessment.
Our GeorgieBoy is now eleven years old, done around 60k miles and has had a hard life.. I've maintained and upgraded as needed, by and large I'm pleased..
Cabinets, beds and furniture:
1 Cabinets are sturdy and well made, no hinges or catches broken.
2 New mattress bought for full timing, the original was indeed 'crap'
3 Chairs and sofa now showing their age but still in good condition.
Appliances and Electrics
1 Cooker had been replaced by previous owner to a SMEV, apparantly the US Stove was crap..
2 Fridge by Norcold has performed brilliantly in all climates, only repair has been a new igniter board, cost around £80 .. it was easily replaced.
3. Water heater, by Atwood.. no problems, I fitted a Hotrod electric heater last year, works great.
4 Hot Air heaters (2) no problems but they are inneficient, too much heat is lost from the exhaust, drink LPG and drain the batteries quickly.
5. Air con (2) by Dometic.. they are efficient and have not broken down.
6. Battery Charger was replaced with a Victron Multi Plus. charger/convector, the original was little more than a 12v power supply.. useless.
7. TV Replaced, nothing wrong with the old but the valves were taking a while to heat up ..
8. Shower, sinks, taps and toilet all good as new .. no issues.
new fresh water pump fitted this year.
Coachwork
No complaints, no leaks, windows are sound, blinds are good, lockers are water tight.
Roof re coated last year.
Idiot Lights
Black and grey tank gauges never work, but you know when a black tank is full without an idiot light ..
Fresh water and LPG gauges work fine.
Chassis and engine
Cummins 5.9lt turbo diesel, 14 mpg never misses a beat, but I had to fit a new starter motor £150 and fuel solenoid valve, £289
a DIY service including fan belt, oil and fuel filters costs about £115
Chassis by Spartan, purpose built RV chassis , built to last, no problems. takes about half a day to grease.
Summing up,
It is a well built RV that could have benefited from a better bed, cooker and charger.. other than that.. :thumb:
So is it crap ? .. no, but there is plenty of room for improvements.
Author Tom Sturgeon once wrote (paraphrased), "90% of everything is crud." It's not really that bad, but most of us have to start with a routine RV. Even the best leave a lot to be desired. Cabinets, beds and some of the furniture are nothing but cheap, stapled-together trash. Appliances are inefficient, expensive, hard to repair and unreliable. Most of the money we spent was wasted on "flash'n dash" idiot lights, gauges that don't gauge, converters that don't convert, leaky windows, "attractive decorator fabrics"
Coachwork
Idiot Lights
Chassis and engine
Summing up,
