Any Ideas What This Might Be - Thanks (1 Viewer)
PP Bear
7,852
28,996
Kent, UK
Auto Trail Dakota SE
Tidying up the wiring under the bonnet, when I traced 2 wires down behind the front grill and then crossmember and found this simply dangling at the end of the wires, behind the bumper.
I'm guessing it's something like an ariel or antenna, but whatever it is, it's full of rusty water and permanently sealed.
Anybody come across one before or anybody know exactly what it is. I traced the wiring back again and it heads from the engine compartment into the cab, but can't locate where it originates from.
The item is on the right in the pictures, the other part being padding and an old sticky pad that had meant to hold it in place.
Thanks in advance:)
18,049
48,216
Weird, but as an off the wall guess it might be an aerial for a tracker.
Reactions: f6c
PP Bear
PP Bear
7,852
28,996
Kent, UK
looks like a GPS sensor to me, had something similar with the dash cam
Thanks, it might be something to do with a tracker of some description, but don't have either a tracker or GPS fitted to my knowledge.
PP Bear
PP Bear
7,852
28,996
Kent, UK
Snap!!
Thanks.
18,049
48,216
Snap!!
Thanks.
Trackers are not meant to be found. :) If the aerial is under the bonnet then I suspect that is where to look. Look under the wings behind the bulkhead for which you may have to remove the headlights but I'm not sure if you will be any better off if you find it. Just tape it off and be grateful some big brother somewhere is looking over you!
PP Bear
PP Bear
7,852
28,996
Kent, UK
I ve tidied it up and secured it, but I need to know what it is I case I need to replace it. The amount of rusty dirty water that poured out, means that whatever it is, then inside will be a mess.
Thanks.
Reactions: DBK
43,392
49,838
Air temperature sensor?
My first thought also.
Too big for a GPS or Tracker antenna and would expect a single multicore round cable, not a twin flex.
Only real way to know is trace the wire back to its termination point under the dash, which I suspect will just be taped up if not just cut off.
Pffft ! Beaten to it again
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
Oops. Removing the sticky pad will have activated the tracker:
<Broken link removed>
Bailey58
8,848
29,918
Norfolk and Toftir.
Sold
July 2010 (ex tugger)
Don't know about that gizmo but it looks like you've run someone over. (y)
two
Aug 4, 2011
4,906
4,578
West Midlands
A-Class Fiat
If you don’t (think you) have GPS or tracker, but do have an external temp readout, try warming the device up and seeing if the readout changes. Or, if the readout never changes, it could be a broken temp sensor.
53,731
151,143
You could test to see if it is a temperature sensor, you could waft a hair dryer at it and see if the air temp readout on the dash increases.
23,842
72,776
If it is a temp sensor the wires will go in to the main loom somewhere.. But given a temp sensor is usually smaller than a biro cap I suspect it is not..
Tell you what it looks like to me.. some kind of buzzer/sounder
May 22, 2015
1,427
2,599
Wem Shropshire
Carthago E Line 51QB
Been getting away since 2008
i would say temp sensor if its behind the front bumper, thats where it was on my VW.
Abacist
3,810
11,264
Devon
N & B Arto 88F Tag
since 2013
What about an alarm movement sensor? Just a wild stab in the dark!
Jun 17, 2012
2,939
9,995
North Essex
Autotrail Delaware
>12 but <13
It's a reversing buzzer but came with a short lead..................
Zigisla
2,583
3,110
Gosport, Hants
Sunlight A72
If we are going down the buzzer route. Could it be the step out warning buzzer?
23,842
72,776
As said it could be a GPS sensor. Found this online which is similar,
Shawn
It is very unlikely to be a GPS sensor because the connecting cable should be coax :)
two
Aug 4, 2011
4,906
4,578
West Midlands
A-Class Fiat
There are two wires going into it. There must be a clue there (but it hasn't helped me yet).
43,392
49,838
I think 'full of rusty water' may be a clue. :D
