Any Ideas What This Might Be - Thanks (1 Viewer)
PP Bear
7,807
28,782
Kent, UK
Auto Trail Dakota SE
Tidying up the wiring under the bonnet, when I traced 2 wires down behind the front grill and then crossmember and found this simply dangling at the end of the wires, behind the bumper.
I'm guessing it's something like an ariel or antenna, but whatever it is, it's full of rusty water and permanently sealed.
Anybody come across one before or anybody know exactly what it is. I traced the wiring back again and it heads from the engine compartment into the cab, but can't locate where it originates from.
The item is on the right in the pictures, the other part being padding and an old sticky pad that had meant to hold it in place.
Thanks in advance:)
DBK
18,029
48,100
Plympton, Devon
PVC, Murvi Morocco
Weird, but as an off the wall guess it might be an aerial for a tracker.
Reactions: f6c
PP Bear
PP Bear
7,807
28,782
Kent, UK
looks like a GPS sensor to me, had something similar with the dash cam
Thanks, it might be something to do with a tracker of some description, but don't have either a tracker or GPS fitted to my knowledge.
Jul 29, 2013
9,071
18,540
Salisbury
Hymer B678DL A class
since 2011
Could be a tyre pal repeater
DBK
18,029
48,100
Plympton, Devon
PVC, Murvi Morocco
Snap!!
Thanks.
Trackers are not meant to be found. :) If the aerial is under the bonnet then I suspect that is where to look. Look under the wings behind the bulkhead for which you may have to remove the headlights but I'm not sure if you will be any better off if you find it. Just tape it off and be grateful some big brother somewhere is looking over you!
Jun 17, 2012
2,933
9,932
North Essex
Autotrail Delaware
>12 but <13
Air temperature sensor?
PP Bear
PP Bear
7,807
28,782
Kent, UK
I ve tidied it up and secured it, but I need to know what it is I case I need to replace it. The amount of rusty dirty water that poured out, means that whatever it is, then inside will be a mess.
Thanks.
Reactions: DBK
43,331
49,467
My first thought also.
Too big for a GPS or Tracker antenna and would expect a single multicore round cable, not a twin flex.
Only real way to know is trace the wire back to its termination point under the dash, which I suspect will just be taped up if not just cut off.
Pffft ! Beaten to it again
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
Oops. Removing the sticky pad will have activated the tracker:
<Broken link removed>
Bailey58
8,817
29,589
Norfolk and Toftir.
Sold
July 2010 (ex tugger)
Don't know about that gizmo but it looks like you've run someone over. (y)
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
If you don’t (think you) have GPS or tracker, but do have an external temp readout, try warming the device up and seeing if the readout changes. Or, if the readout never changes, it could be a broken temp sensor.
Lenny HB
53,448
150,064
On the coast in West Sussex
Hymer B678 DL
You could test to see if it is a temperature sensor, you could waft a hair dryer at it and see if the air temp readout on the dash increases.
Jaws
23,836
72,493
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
If it is a temp sensor the wires will go in to the main loom somewhere.. But given a temp sensor is usually smaller than a biro cap I suspect it is not..
Tell you what it looks like to me.. some kind of buzzer/sounder
May 22, 2015
1,425
2,590
Wem Shropshire
Carthago E Line 51QB
Been getting away since 2008
i would say temp sensor if its behind the front bumper, thats where it was on my VW.
Abacist
3,741
10,736
Devon
N & B Arto 88F Tag
since 2013
What about an alarm movement sensor? Just a wild stab in the dark!
Jun 17, 2012
2,933
9,932
North Essex
Autotrail Delaware
>12 but <13
It's a reversing buzzer but came with a short lead..................
Zigisla
2,580
3,106
Gosport, Hants
Sunlight A72
Getting better month by month.
If we are going down the buzzer route. Could it be the step out warning buzzer?
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
There are two wires going into it. There must be a clue there (but it hasn't helped me yet).
43,331
49,467
I think 'full of rusty water' may be a clue. :D
