Antifreeze (4 Viewers)
Glynn
163
18
Lancashire
Hi,
Which type of antifreeze is suitable for winterizing the MH, I want it for the truma heater/boiler and the hot/cold water etc.
2,347
10,197
Why not drain down ?
2,347
10,197
well, there are special antifreeze for water systems, but frankly, I think it would be unwise to put any anti freeze into drinking water systems..
It will be difficult to remove every last drop without blowing out and flushing several times.. more work than simply draining down ..
G
Glynn
163
18
Lancashire
How do you go about draining the truma boiler then ?.
2,347
10,197
They normally have an automatic frost protection drain valve on the fill line under the boiler that drains it when the ambient drops to about + 3c .
It can operate manually by lifting the knob, to keep it open use a clothes peg.
lunarman
2,156
2,451
South Glos
since 1994
There should be a valve that looks like the attached picture in the water inlet ( It may be some distance fro the boiler). Lift the lever and the boiler will drain.
Lunarman
Sep 29, 2009
198
60
norwich
swift escape 640
since 2009
how thats for coincedence. names glyn [just one n ] and i have a 705 allso !! and you dont see to many do you ?
re draindown all we do is open both the tank drain valve and lift the hot water drain tap in same compartment.i have found that opening the taps in centre position allows air in and allows all water to drain out. havent had any problems doing it this way
Sundowners
3,289
3,571
Suffolk/Central Portugal
37 years
We were discussing this in an RV shop---------They do not like antifreeze in the boiler as it (should have) an annode rod inside, the antifreeze is corrosive and will attack it--------so, drain boiler and isolate it, then antifreeze rest of system if you wish (RV potable antifreeze)
Nigel
43,337
49,538
Nigel
agreed Nigel...you can buy a boiler bypass system (fitted for life) which is a series of valves/taps and pipes to temporarily bypass the boiler for winterizing.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Slight correction if I may
The auto valves normally Push Down to drain and Drop Down when freezing is imminent +3c and cant be re set untill the temp reaches +8c
The peg trick is to stop it dropping, ie hold it up in the closed position when you don't want it to drain automatically
At least all those ive come across work that way
Geo
Geo
Add that to LunarMan's lift up valve and that's what we have.
Glad of this thread, I drained down and had forgotten the manual lift up valve. Now sorted.
2,347
10,197
Geo
senior moment .. :Doh: thanks Geo..
G
Glynn
163
18
Lancashire
Lunarman
Where exactly will it drain to ?.
2,347
10,197
So I take it there must be a drain pipe going through the floor.
yes, if you look under the van below the valve you should be able to see it ..
JockandRita
11,468
150,295
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
And draining the taps etc ? any good tips.
Yes Glynn,
Switch off the 12v power to the pump, and then open the taps as previously mentioned, to allow air in and water out. Once all water is drained from the system, close the taps, then you can operate the 12 sytem again, without burning out the pump.
Some systems have inline drain taps to asisst with draining off.
I wouldn't recommend the use of an antifreezing agent either.
Regards,
Jock.
G
Glynn
163
18
Lancashire
Yes Glynn,
Regards,
Jock.
How's that going to empty the pump and the pipes to them , not to mention the shower. Surely it needs blowing out also ?.
JockandRita
11,468
150,295
Lincs/Cambs border
N+B Flair 8000i
Are you taking the urine by any chance? :winky:
Empty fresh water tank, and hot water tank, open all taps including shower tap, and any inline drain valves. Any remaining water in the system................drains to ground, outside of the vehicle. If you drain down properly, you won't need to blow out with compressed air.
Pending what toilet flush system you have, you may have to drain down the flush tank too.
Hope this clarifies things for you. :thumb:
Cheers,
Jock.
Jock.
Or not as the case may be. I worry that because of the use of flexi pipes it would be all too easy to get a high spot trapping water.
I think a blow job may be a good idea. What man doesn't, but I've never bothered to date.
JockandRita
11,468
150,295
Lincs/Cambs border
N+B Flair 8000i
Hence leaving open all the drain valves Brian. That way, should any water be trapped and freezes, it is able to expand without creating pressure on any of the connections.
Regards,
Jock.
