Antifreeze
Discussion in 'Motorhome Chat' started by Glynn, Oct 15, 2010.
  1. Glynn
    Glynn Read Only Funster
    May 2, 2010
    163
    18
    Lancashire
    Hi,
    Which type of antifreeze is suitable for winterizing the MH, I want it for the truma heater/boiler and the hot/cold water etc.
  2. wivvy's dad
    wivvy's dad Read Only Funster
    Jun 22, 2010
    3,218
    1,807
    48.066895,12.862673
    Try boat chandlers - anti-freeze for boats
  3. scotjimland
    Jul 25, 2007
    28,934
    25,601
    Why not drain down ?
  4. Glynn
    May 2, 2010
    163
    18
    Lancashire
    I prefer to antifreeze it.
  5. scotjimland
    Jul 25, 2007
    28,934
    25,601
    well, there are special antifreeze for water systems, but frankly, I think it would be unwise to put any anti freeze into drinking water systems..
    It will be difficult to remove every last drop without blowing out and flushing several times.. more work than simply draining down ..
  6. Glynn
    May 2, 2010
    163
    18
    Lancashire
    How do you go about draining the truma boiler then ?.
  7. scotjimland
    Jul 25, 2007
    28,934
    25,601
    They normally have an automatic frost protection drain valve on the fill line under the boiler that drains it when the ambient drops to about + 3c .
    It can operate manually by lifting the knob, to keep it open use a clothes peg.
  8. lunarman
    lunarman Funster Life Member
    Sep 23, 2008
    1,469
    882
    South Glos
    There should be a valve that looks like the attached picture in the water inlet ( It may be some distance fro the boiler). Lift the lever and the boiler will drain.
    Lunarman
  9. nifty fifty
    nifty fifty Funster
    Sep 29, 2009
    141
    29
    norwich
    how thats for coincedence. names glyn [just one n ] and i have a 705 allso !! and you dont see to many do you ?
    re draindown all we do is open both the tank drain valve and lift the hot water drain tap in same compartment.i have found that opening the taps in centre position allows air in and allows all water to drain out. havent had any problems doing it this way
  10. Sundowners
    Sundowners Funster Life Member
    Oct 30, 2007
    2,357
    1,442
    Suffolk
    We were discussing this in an RV shop---------They do not like antifreeze in the boiler as it (should have) an annode rod inside, the antifreeze is corrosive and will attack it--------so, drain boiler and isolate it, then antifreeze rest of system if you wish (RV potable antifreeze)
    Nigel
  11. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,903
    17,577
    YO11 2BD
    agreed Nigel...you can buy a boiler bypass system (fitted for life) which is a series of valves/taps and pipes to temporarily bypass the boiler for winterizing.
  12. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,733
    5,964
    Mansfield,Notts
    Slight correction if I may
    The auto valves normally Push Down to drain and Drop Down when freezing is imminent +3c and cant be re set untill the temp reaches +8c
    The peg trick is to stop it dropping, ie hold it up in the closed position when you don't want it to drain automatically
    At least all those ive come across work that way
    Geo
  13. hilldweller
    Dec 5, 2008
    27,197
    26,182
    Macclesfield
    Add that to LunarMan's lift up valve and that's what we have.
    Glad of this thread, I drained down and had forgotten the manual lift up valve. Now sorted.
  14. scotjimland
    Jul 25, 2007
    28,934
    25,601
    senior moment .. :Doh: thanks Geo..
  15. Glynn
    May 2, 2010
    163
    18
    Lancashire
    Where exactly will it drain to ?.
  16. scotjimland
    Jul 25, 2007
    28,934
    25,601
    with any luck, ... onto the ground under the van :thumb:
  17. Glynn
    May 2, 2010
    163
    18
    Lancashire
    So I take it there must be a drain pipe going through the floor.
  18. scotjimland
    Jul 25, 2007
    28,934
    25,601
    yes, if you look under the van below the valve you should be able to see it ..
  19. Glynn
    May 2, 2010
    163
    18
    Lancashire
    And draining the taps etc ? any good tips.
  20. JockandRita
    JockandRita Funster Life Member
    Aug 2, 2007
    5,848
    8,133
    Lincs/Cambs border
    Yes Glynn,
    Switch off the 12v power to the pump, and then open the taps as previously mentioned, to allow air in and water out. Once all water is drained from the system, close the taps, then you can operate the 12 sytem again, without burning out the pump.
    Some systems have inline drain taps to asisst with draining off.
    I wouldn't recommend the use of an antifreezing agent either.
    Regards,
    Jock.
