Another inverter question (3 Viewers)
Sep 18, 2015
698
702
Selby, North Yorkshire
Rapido 8066DF
Hi,
I have a tv and 300w mod sine inverter connected through a din socket 12v/120w with a 12v 2 way split for the 2 cig lighter plugs each outlet is 3.5 amps with a 10 amp fuse, i have to confess like this for 4 months have read on here the inverter uses 25 amp is that correct if it is why is it still working?
Many thanks for a bit of advice here,
Bill
BILL 875
Sep 18, 2015
698
702
Rapido 8066DF
Many thanks Brian it has only had a tv- 2.1 amps and a well known sat box- ? amps 4 or 5 i suppose no hair dryers or the like.
Regards
Bill
43,345
49,546
Yep, correct.
Tv + satbox total 84 Watts @ 230v = 0.36 amps
But....84 watts @ nominal 12v = 7amps/hour from battery. (Plus inverter loses)
6 hours viewing will ALMOST drain a single 100ah battery to 50%....time to recharge!
Should be ok using the DIN socket as long as you dont plug anything else in as well.
