What do you do when the gas bottle reaches it's expiry date,does it get tested or do you need to buy a new one?
Is the info not on the Alugas site ?
I have Gaslow. .. they say
After 10 years you must return your cylinder to a Gaslow dealer who will exchange it and charge a replacement fee.
NO, they say 15 years?
Phone Chris at Autogas2000 01845 526 783Getting away from my question guys,it's Alugas bottles I want the info on.
.. as I quoted , from this page Broken Link Removed
The Gaslow R67 11kg Refillable Cylinder is designed for installation in your caravan/motorhome locker
They can be filled using the Gaslow Filler Kit at thousands of LPG stations across the UK and Europe
The cylinders are manufactured from steel and carry our full 10 year warranty as requested by the R67 standard.
For complete safety the R67 approved filler valves automatically shut off the gas when the cylinder is 80% full, preventing the dangers associated with overfilling.
It also has an over pressure safety relief valve.
The outlet valve has a built in filter to prevent inpurities in the gas damaging the regulator.
The cylinder has an excess flow valve to restrict the flow of gas if the hose ruptures.
Our new cylinder is fitted with a new mechanically accurate contents gauge.
We recommend using the Gaslow 21.8 LH Stainless Steel Hose to connect to your caravan/motorhome regulator
Capacity (80%): 21 litres
Height: 560mm
Diameter: 304mm
Empty Weight: 12.4kg
Outlet Connection: 21.8LH thread
